SDA crossover upgrades
I have a pair of sds srs 1a's and they sound just fine. Do we rebuild/replace the crossovers because they wear out or because we think Mathew and the boys at Polk Audio got it wrong. Just curious.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
Joe, you are absolutely right. I have sent and received many messages that have been taken wrong. If i have done so in this case, I apologize, but the comment about the innocent seemed to be kind of a smart **** comment.Did you compensate in your redesign of the crossover for the disparity in the drivers needed for each design? I have a feeling the 6511 to 6503 differences are going to be quite apparent in your work if you did not. I am seeing a future of weak Dimensional sound.
I have done no other compensation, at this point, than what Polk did when they made their upgrade (redesign as others see it) to the 1.2. I truly have a hard time believing so many intelligent members don't see that Polk used the same crossover on both of these drivers. Once again, if someone does the math on the dimensional series circuit between the two cabinets of the 1.2 the stereo drivers have exactly the same value components as the dimensional drivers. That is ALL I mentioned doing to the dimensional circuit; exactly what Polk did but with a different driver. Albeit a different driver that Polk saw fit to use the same crossover on. Will it sound different? I am sure it will. Will it be better than the SRS sounded originally? maybe, maybe not. If it doesn't, it is easy enough to remove 4 parts and put 4 others back in and switch the interconnect cable back to the original layout. It is a simple mod, and just as simple to go back to original if it doesn't make an improvement. Maybe it should be considered more like research than a mod. I am willing to bet that the SDA effect will be almost no different than the 1.2's in their original form, though I am sure the tonality will be somewhat different due to the different driver characteristics.You are adding a lot of Ohms to the SDA side using the crossover for the 1.2 or 1.2tl. While it may make the dimensional side easier to drive for the amp you are also attenuating the SDA effect. Not a trade off I would vote for in the larger SDA's. You almost have to add more resistance to the stereo side to compensate or rewire the Dimensional side to drop the ohms back down.
Actually I will be keeping the same impedance that I have already. It will be different than the actual 1.2 since , as DK points out above, the impedance of the two different drivers is different.
As many of you think this could very well be a waste of time, but as mentioned before it is too easy not to try and if it doesn't work to put it back like it was.If con is the opposite of pro, is Congress the opposite of Progress?!
Monitor 5Jr, Monitor 5, RTA12, RTA 15TL, SDA 2A, 1c, SRS 2, 1.2TL, CRS, Atrium. -
Another point to note that the SRS, 1.2 and 1.2TL are similar is the parts list posted in the sticky. All the crossovers have the same part # with a different version designation at the end. If they were completely redesigned it would stand to reason that they would have entirely different model #'s instead of designations to indicate different versions of the same.If con is the opposite of pro, is Congress the opposite of Progress?!
michael1947 wrote: »I have a pair of sds srs 1a's and they sound just fine. Do we rebuild/replace the crossovers because they wear out or because we think Mathew and the boys at Polk Audio got it wrong. Just curious.
We usually redo crossovers to update/upgrade the parts from there 20+ year old crossovers as they do wear out over time, and honestly they make better parts for these now.
There are also those that mod them with ideas from Polk engineers as well. Like the 4.1TL mod for SDA2b's and the CRS+ so they can use the Tri-Laminate tweeter with these models.
What Oliver is doing is shooting for something I have not seen before on this forum. I applaud the effort but I think some key items are being overlooked. -
oliverbubbles wrote: »Actually I will be keeping the same impedance that I have already. It will be different than the actual 1.2 since , as DK points out above, the impedance of the two different drivers is different.
Actually you won't be keeping the same impedance. The issue you are not seeing is that the two crossover designs and drivers are different. So you will be gaining impedance with the new crossover design. Lets look at the speaker in both forms. I do not have the figures in front of me but for arguments sake lets say Original SRS's have a dimensional impedance of 8 ohms and 1.2TL's have an impedance of 4ohms. By not changing drivers with to compensate you will be doubling the ohm's rating that the 1.2TL crossover will see. Do you see what I mean? In a way you will be attenuating the circuit. In what way I am not sure but the ohm sweep is different for each as well as there response curves. These all have to be taken into account before changing the crossover. -
Caps, especially inexpensive eletrolytic caps, have a finite shelf life of anywhere from 10-15 years many time less. So we rebuild to replace old worn parts and while we are in there we change things up that have proved to be better in the span of when something was assembled like in the 80's until now. We replace inductors on the advice of "Matt and the Boys" because it's been roughly 20 years and components and technology change by either being something new and or cost is dramatically less now. We change resistors to something like Mills wire wound non-inductive because they sound better, etc.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
I will be keeping the same impedance as i will be keeping the same drivers in the same wiring configuration. The crossover (effectively the 1.2 crossover) will see a different impedance than what it would normally see in the 1.2 since the driver impedance is different. What this will do is effect the response curve as the actual crossover frequency will be somewhat different. This can be easily compensated for with the inductor /capacitor values. the main concern I have is the differing output levels of the drivers due to impedance/ and efficiency. This too can be compensated for but does then get more in depth. But as I've said several times; if it doesn't work it can be changed back very easily.If con is the opposite of pro, is Congress the opposite of Progress?!
The SRS uses 6503's in the stereo and dimensional circuits. The 1.2 and the 1.2TL use 6503's in the stereo circuit and 6511's in the dimensional circuit. Therefore, there is no rational basis for thinking that the SRS crossover "matches" both the 6503 and 6511 drivers. Also, the 6503 and 6511 have very different electrical and mechanical characteristics. For example, the DC resistance of the 6503 is 6.15 ohms compared to 2.7 ohms for the 6511. The maximum impedance of the 6503 is 39.78 ohms compared to 21.28 ohms for the 6511.
I am not sure what the nominal impedance is for either of these drivers. I would assume however that the 6503 is roughly double that of the 6511. this is somewhat (though not precisely) verified by the DCR specs given by DK. above. lets look at the dimensional circuits as a whole in both models.
The numbers i have here are simply numbers rounded from DK's specs above. they are IN NO WAY intended to represent the actual impedance of these drivers. say the SRS has 4 drivers of roughly 6 ohms each in a series/ parrallel configuration and the crossover is designed for this nominal 6 ohm total impedance and only sees these 4 drivers to get this impedance match.
now we look at the 1.2 drivers; say their are 4 of them in each cabinet, just as the SRS's each cabinet wired seies parallel with 3 ohm speakers. this gives us 3 ohms in each cabinet. but now this crossover not only sees these 4 drivers but also the 4 drivers in the other cabinet that these are in series with. This equates to 6 ohms total impedance, just as the SRS's. the only difference id that we now have all components in the dimensional circuit of both cabinets run in series with each other so not only do the driver electrically add together but so do the crossover components in this circuit.
Just like DK and others have built the same crossover for their speakers using different components, Polk did the same thing here between these 2 models. this describes the dimensional circuit only.If con is the opposite of pro, is Congress the opposite of Progress?!
oliverbubbles wrote: »Joe, you are absolutely right. I have sent and received many messages that have been taken wrong. If i have done so in this case, I apologize, but the comment about the innocent seemed to be kind of a smart **** comment.oliverbubbles wrote: »To me it seemed arrogant. I could have misinterpreted, I have surely done so before.
Perhaps it seemed arrogant to you because that is the world you live in. It is interesting that you accuse me of arrogance while your discourse is sprinkled with arrogant, passive-aggressive remarks. Even if I were the most arrogant jerk that ever lived, plus a serial killer, what difference would that make pertaining to the soundness of my ideas? Either my ideas make sense or they do not. I don't understand the relevance of any real or perceived character flaws to the soundness of my comments. I would not refuse a cure for cancer if it were invented by a serial killer.
I have continually and consistently pointed you toward the source of knowledge for modding SDA's:DarqueKnight wrote: »Why don't you submit an inquiry to Polk's engineering department about your modification plans? That is what I did prior to doing my first SDA modification in 1990. Polk engineers were very helpful in pointing out certain pitfalls to avoid. Electrical circuit modification is not just a simple matter of reading a schematic and substituting parts. Schematics don't, and can't, tell the whole story about the speaker designer's performance goals. If you submit an inquiry, it will have to be forwarded through Polk's customer service department (contact Kim Jasper). The engineering department no longer communicates directly with the public.DarqueKnight wrote: »What others have done in the past (and I'm speaking of legitimate modifications) have been done under the advisement of Polk's engineering department. Do what you want with your speakers, but if you are interested in performance improvement, it would seem prudent to seek advisement from the people who designed and built them.DarqueKnight wrote: »The SRS and 1.2 cabinets are different with regard to bracing, panel construction and in the way the panels are joined together. They are completely different cabinets. I understand that you find this difficult to believe. Again, Polk's engineering department will be able to provide additional insight. I hope you consider them to be a credible source of information about SDA's.
This was not arrogance. This was showing concern about you and others getting into an unfortunate situation with your speakers.
In contrast, these type of comments could be construed as insights into your character:oliverbubbles wrote: »...surely I am not the only one outside of Polk that has figured that out.oliverbubbles wrote: »I truly have a hard time believing so many intelligent members don't see that Polk used the same crossover on both of these drivers. drivers is different.
Why do you feel the need to passively-aggressively question the intelligence of forum members? While I applaud your ability to look at schematics that some of us have been using for over two decades and "see" things that we overlooked, I wonder why you can't just show us the error of our ways without calling our intelligence into question?
Along those lines, I have a question. I have attached a copy of the forward statement from the 1989 Polk Audio In Field Technical Manual. Warranty Manager Helen Yarbor states, in all caps (which is the written equivalent of screaming):
"IT IS IMPORTANT TO REALIZE THAT WE MANUFACTURE A VARIETY OF 6 1/2" DRIVERS WHICH ARE OPTIMIZED FOR SPECIFIC MODELS. THEREFORE IT IS HIGHLY RECOMMENDED THAT ONE READS THE QC STICKER ON THE BACK OF EACH DRIVER AND MATCH THE PART NUMBER TO ITS PARENT MODEL USING THE CROSS REFERENCE SUPPLIED IN THIS MANUAL."
Ms. Yarbor's comment appears to indicate that drivers are not as interchangeable among SDA models as you purport. Am I interpreting this correctly, or am I overlooking something?oliverbubbles wrote: »DK Again I respect your opinions as I can tell from your posts that you are very intelligent and thorough I am just not the kind of person to look to you as the Polk "god" as many on these forums appear to do.
That's kind of (passive-aggressively) over the top don't you think? I certainly don't consider myself to be a Polk "god" and it is insulting to the membership that you ascribe this to them. If I did consider myself a "Polk god", Would I have consistently referred you to Polk's engineering department? Since you are discussing model conversions, which is not a trivial undertaking, I suggested that you confer with Polk about that.
With regard to whether the change from the SRS to the 1.2 is a mere "upgrade" or a "redesign", I can only refer you to what Polk said. Their marketing literature said the 1.2 cabinet was a new "monocoque" design. They said the crossover was "redesigned" to enhance imaging and to present and easier load to an amplifier. Perhaps their use of the words "monocoque cabinet structure" and "crossover redesign" were just marketing hype. You probably won't have to go to Polk's engineering department for clarification on those points. Polk's customer service manager, Kim Jasper, should be able to provide such information.
As for me, since I own both the SRS and the 1.2TL, I can just look inside the cabinets and see that they are very different. This also applies to the crossover circuits. However, I don't doubt that you might look inside my speaker cabinets and not see much difference.oliverbubbles wrote: »Being the best they can be doesn't mean that I will end up with any of the SRS crossover designs in the end. i want them to be the best they can be, not necessarily the best Polk design they can be.oliverbubbles wrote: »As many of you think this could very well be a waste of time, but as mentioned before it is too easy not to try and if it doesn't work to put it back like it was.
Experimentation is not a waste of time, if it is appropriately conducted. However, as I and others have pointed out, you are overlooking many important design factors. You may not be able to "put it back like it was". In any event, enjoy your venture.oliverbubbles wrote: »One thing that jumps out to me is that I have not found a post where you came up with a new idea or concept on your own; it appears to have all come from someone else making a suggestion.
Really Oliver...why would this jump out to you? You talk like it's a bad thing that I take a conservative approach to modifying expensive vintage loudspeakers that would be close to impossible to replace if I screwed something up.
***Guess what?*** I am not in audio to come up with new ideas and concepts. In fact, I have stated many times that I do not enjoy the work involved in researching and implementing modifications. I am in audio for the enjoyment of music. It just so happens that my musical enjoyment can be greatly enhanced by carefully executed modifications. I get enough electronics "play time" at work. When I come home I just want to listen to music.oliverbubbles wrote: »I am not knocking you for that, it may very well be a much safer road to follow than the roads I take, but that is not the way that I am.
I realize that. However, you clearly stated that this thread was aimed at "guys on a budget", many of whom are inexperienced and unknowledgeable in this sort of thing:oliverbubbles wrote: »This post is not really for you "hardcore " guys out there with unlimited budgets but more for the guys on a budget considering crossover upgrades.
Therefore, the "innocents" I referred to were those who might be induced to error and catastrophic misfortune by the abundant misinformation and wild speculation in your posts. We have seen "innocents" start out with your mindset and end up with the following:
1. Passive radiators replaced with active woofers.
2. Tweeters replaced with "upgrade" horn tweeters.
3. "Enhanced" SDA circuitry that makes all music sound like it was recorded in a garage.
4. Drivers replaced with "upgrades" that were totally inappropriate and in some cases electrically unsafe.
5. Brutally butchered, and sometimes burned, crossovers.
Examples of the hack jobs in items 1-5 above periodically show up on eBay, after which we have a great time marveling at the *genius* of the mind behind such "performance enhancements".
As I said before, do what you want to do with your speakers. You asked for discussion and I provided my thoughts.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Oliver, DK is right on all his counts as far as the cabinets are concerned. Different building methods and bracing do change the sound characteristics of a speaker. Go over to a DIY speaker forum and look at what they have done. 1/2 in mdf won't hold a candle to 1/2 inch birch ply and triple bracing a cabinet compared to double bracing is almost night and day.
This comment.Ummm, ok. A cabinet drawer with mortise and tenon joints and a brace underneath does not make it completely different from cabinet drawer with square joints and screws holding it together. the same size and strength drawers serve the exact same function. They are different , but not completely.
Makes you sound very silly, almost as bad as the car is a car comment. There are differences in the cab, the crossovers and the drivers. This isn't something we say just cause we want hear ourselves, its to help people not make mistakes.
I love the fact that you are trying something new but your method of thinking has me worried you will blow something up before long.
And your last post explains what I mean about impedance to a T. You in fact state it for me.now we look at the 1.2 drivers; say their are 4 of them in each cabinet, just as the SRS's each cabinet wired seies parallel with 3 ohm speakers. this gives us 3 ohms in each cabinet. but now this crossover not only sees these 4 drivers but also the 4 drivers in the other cabinet that these are in series with. This equates to 6 ohms total impedance, just as the SRS's. the only difference id that we now have all components in the dimensional circuit of both cabinets run in series with each other so not only do the driver electrically add together but so do the crossover components in this circuit.
So instead of 6ohms total impedance you are going to have somewhere in the neighborhood of 12-14ohms. Do you see what I mean now? That is more than double the impedance so you will be attenuating the circuit.
Just letting you know, I have read your ideas and although commendable, I don't think you thought it through. -
I foresee another pair of Frankenpolks on the used market some day."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
really? that's not arrogance. maybe just compensation. Dude I'm not passive about anything. I can be pretty damn aggressive though. seems a little hypocritical there talking about the world i live in and all. you are correct your attitude, arrogance or not has nothing to do with what works and what doesn't. i tried to apologize for any misconception i may have had but you seem to want to point the me not being wrong in the first place. Either way, **** or not I still respect your opinions.I have continually and consistently pointed you toward the source of knowledge for modding SDA's:
Yes you have and i remember thanking you for that. maybe you missed that part.In contrast, these type of comments could be construed as insights into your character:
I'm an ****, never claimed any different. But these comments must have been misunderstood by you and since that is the cae possibly others. What i meant by them was that I am not the smartest person in the world and others, probably you included are smart enough to know this already so someone else out there has seen this besides me. i apologize to all who may have taken offense to this.I wonder why you can't just show us the error of our ways without calling our intelligence into question?
I don't recall trying to show anybody the error of their ways, dude, I have enough problems of my own. i'm just trying to learn things here, and if you recall this all started by me simply posting my plans, not asking for opinions.Along those lines, I have a question. I have attached a copy of the forward statement from the 1989 Polk Audio In Field Technical Manual. Warranty Manager Helen Yarbor states, in all caps (which is the written equivalent of screaming):
This is all well and good but doesn't apply to what I have been saying (exactly). different drivers have different characteristics and will therefore sound different if placed in similar circuits. this does NOT mean that they will not be a close substitution or possibly a better substitution. And yes they could always sound worse. I have not shied away from this fact and have acknowledged it several times. Polk did this in my 2A's to use up old parts, and they sound better than any other speaker i have.That's kind of (passive-aggressively) over the top don't you think? I certainly don't consider myself to be a Polk "god" and it is insulting to the membership that you ascribe this to them. If I did consider myself a "Polk god", Would I have consistently referred you to Polk's engineering department? Since you are discussing model conversions, which is not a trivial undertaking, I suggested that you confer with Polk about that.
Dude, read what i write; I never said you thought you were a "god", just that others act like you are. man take what you can get, if you're like most of us your wife never treats you that way. I am sorry if I am wrong, i am just assuming you are straight.Really Oliver...why would this jump out to you? You talk like it's a bad thing that I take a conservative approach to modifying expensive vintage loudspeakers that would be close to impossible to replace if I screwed something up.
Once again, read what I wrote, and this time what you even copied and pasted from my post. I did. say being that way was a bad thing at all, it is just not the way i am. I am extremely competitive and if i do the same thing the next guy does i will only be playing at the same level. not that i am trying to win anything here, just explaining my nature.I realize that. However, you clearly stated that this thread was aimed at "guys on a budget", many of whom are inexperienced and unknowledgeable in this sort of thing:
exactly! and this mod will cost me less than $20. if it doesn't work I can put it back to the way it was and only be out less than $20.Therefore, the "innocents" I referred to were those who might be induced to error and catastrophic misfortune by the abundant misinformation and wild speculation in your posts. We have seen "innocents" start out with your mindset and end up with the following:
Once again I tried to apologize for the arrogant comment if I took the innocent thing differently than you meant it. but now you seem to be calling into question my intelligence with the wild speculation and misinformation thing. again, sounds a little hypocritical to me. Those things don't appear to be anywhere closely related to my mindset, but I see your point. Again you compare my mindset to that and then make the *genius* comment. This seems to be calling my intelligence into question. Check yourself man, hypocrisy is not a trait that most people think of as good for ourselves. But hey, if you're good with it I am too.If con is the opposite of pro, is Congress the opposite of Progress?!
I realize this completely, i worked in car audio for 22+ years and designed and built the loudest car in the world on the IASCA circuit, 2 years in a row. We were one of the first to break 176db when others were several db below this. AND this was done WITHOUT a factory sponsor on a budget of less than $25000 when the closest competitor was factory sponsored by more than one manufacturer and on a rough budget of about 1/4 million. We didn't get to replace our drivers or amps every run since we were not factory sponsored. The system was made to work and to last.
What does that have to do with any Polk speaker, NOTHING. but I let you know to tell you i know how cabinets work. I know the use of different materials, but that is not what happened here. Polk removed braces to open up the cabinet, if I had to guess why, it would have been to allow some of the standing waves inside the cabinet to help move the passive better. Did they make the cabinet thicker, or out of different material? not to my knowledge. they cut grooves in the cabinet boards so as to break up any sympathetic vibrations. DK's "monocoque" is simply describing an exoskeleton because they removed the internal bracing. I've built more cabinets than i care to think about (for home and automobile) out of everything from fiberglass to 1/2" steel plate. I've canceled resonances, damped drivers and cabinets and baffles, and then went back and added resonances back in where beneficial. There is NO rocket science to building speaker cabinets, and these are no different. In fact these cabinets are pretty poor. if they weren't using 6.5" active drivers they would never hold up.So instead of 6ohms total impedance you are going to have somewhere in the neighborhood of 12-14ohms. Do you see what I mean now? That is more than double the impedance so you will be attenuating the circuit.
how do you get that. 4 3ohm drivers per cabinet wired series parallel as they are in these speakers will equal (3 ohms per cabinet in series with 3ohms from the other cabinet) 6ohms. the same as 4 6ohm drivers in a single cabinet.If con is the opposite of pro, is Congress the opposite of Progress?!
This letter also states that a suitable replacement will be recommended. indicating that some drivers are indeed interchangeable.If con is the opposite of pro, is Congress the opposite of Progress?!
Knock yourself out Oliver, I look forward to a new generation of better SDA's.
The mere fact that you feel the oldest SDA's you own, the SDA 2A's sound the best out of the 1C's and SRS's leaves me a little suspect because I have spent time with all those models and the 2A's, IMO, don't compete on any level with the newer SDA's. The 1C's, IMO, are about the best SDA's going as they are sort of the "sweet spot" for SDA's as in they fit in a majority of rooms without too much difficulty, they are fairly easy to drive comparatively, they aren't huge, they have a generous and forgiving sweetspot comparatively so one can listen off-axis and out of the sweet spot w/o too much listening penalty. They are fairly laid back in their presentation, most models have the ability to be used with the AI-1 interpahse cable, plus they look nice.
Again, just IMO, but there aren't too many here who would feel the 2A's trumph both the 1C's and SRS's all things being equal.
oliverbubbles wrote: »how do you get that. 4 3ohm drivers per cabinet wired series parallel as they are in these speakers will equal (3 ohms per cabinet in series with 3ohms from the other cabinet) 6ohms. the same as 4 6ohm drivers in a single cabinet.
Because they are double the impedance. How are you not seeing this? Double the impedance in each cab, now wire them as they should be in the 1.2tl crossover and you get???????? That's right 12+ ohm's. The crossover changes the wiring so that the impedance doubles across the two speakers. Combining 6+ ohms in each cabinet gets you 12+ ohms total across the circuit. I do not know how to explain it any better. -
I apologize Joe, I do see that and i now see where the confusion is coming in. I have been describing this in "effective" terms as compared to each other instead of actual terms as you are here. That is my fault and i am sorry to have confused you. i may have also confised you in my answer to your previous question. so let me rephrase my previous answer; yes I am making adjustments to compensate for this actual difference.
H9, I think a big reason i like the 2's so much better is their simplicity and to me it shows in the sound as being less colored to my ears.If con is the opposite of pro, is Congress the opposite of Progress?!
Actually I believe the single board 1C's are equally as simple w/the exception of the progressive point source tweeter array. But I certainly won't say you're not allowed to like the 2A's better. It's just more uncommon for those that have compared them to later models.
I apologize Joe, I do see that and i now see where the confusion is coming in. I have been describing this in "effective" terms as compared to each other instead of actual terms as you are here. That is my fault and i am sorry to have confused you. i may have also confused you in my answer to your previous question. so let me rephrase my previous answer; yes I am making adjustments to compensate for this actual difference.
I would like to elaborate on this. I have the components to compensate for this impedance difference but plan on trying it first with the stock component values of the SRS and then the stock values of the 1.2 and then if necessary make any changes that are needed. I have not pre-adjusted anything. If an attenuation circuit is needed I will rewire all 4 dimensional drivers per cabinet in parallel (which will then be in series with the other cabinet wired the same way) and then place the attenuation circuit on the dimensional drivers so as not to have to attenuate the stereo drivers and the tweeters, but only one portion of the crossover circuit. This should give the same listening levels as I have now. As I mentioned before; the biggest concern I have is exactly what I think Joe is getting at; the difference in levels and the response curve of the dimensional circuits as compared to the other circuits in the system.If con is the opposite of pro, is Congress the opposite of Progress?!
How do you plan on attenuating a woofer circuit? Seems like a huge waste of power."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
oliverbubbles wrote: »I am sorry if I am wrong, i am just assuming you are straight.
You assume correctly...Mr. Bubbles.oliverbubbles wrote: »Dude I'm not passive about anything. I can be pretty damn aggressive though.
Me too.oliverbubbles wrote: »Yes you have and i remember thanking you for that. maybe you missed that part.
Yeah, I saw that...you're very welcome.oliverbubbles wrote: »I'm an ****, never claimed any different.
O.K.oliverbubbles wrote: »i apologize to all who may have taken offense to this.
No offense taken on my part. As I clearly stated, I was...and still am...amused. From the comments I have read from others, I don't think anyone else took offense either.oliverbubbles wrote: »DK's "monocoque" is simply describing an exoskeleton because they removed the internal bracing.
Why did you refer to the cabinet design as "DK's "monocoque"? The term "monocoque" was Polk's descriptive term, not mine.oliverbubbles wrote: »There is NO rocket science to building speaker cabinets, and these are no different. In fact these cabinets are pretty poor. if they weren't using 6.5" active drivers they would never hold up.
What do you mean by "if they weren't using 6.5" active drivers they would never hold up"? It appears that you are saying that Polk needed to use small drivers because the allegedly "poor" cabinets could not withstand the pounding from larger drivers. Using a larger number of smaller drivers can be more sonically advantageous than a single larger driver.oliverbubbles wrote: »This letter also states that a suitable replacement will be recommended. indicating that some drivers are indeed interchangeable.
Well, common sense should indicate that if Ms. Yarbor wanted her "suitable replacement" comment to include drivers, she would have said that. She had the "driver" comment in bold all-capital type and the "components" comment later in normal type. This letter was written sometime in 1988 for the 1989 Field Service Manual. I don't recall that there were issues with driver availability during the time this was written. There is nothing in the manual about substituting one driver with another. Sometimes there were issues with sourcing electronic components (polyswitches, capacitors, etc.) and connectors.
Long after SDA's were discontinued, there were supply problems with some drivers (the 6513 comes to mind). "Workable" substitutions were suggested, but it was plainly stated that such substitutions were not optimal.oliverbubbles wrote: »I am extremely competitive and if i do the same thing the next guy does i will only be playing at the same level.oliverbubbles wrote: »not that i am trying to win anything here, just explaining my nature.oliverbubbles wrote: »...i worked in car audio for 22+ years and designed and built the loudest car in the world on the IASCA circuit, 2 years in a row. We were one of the first to break 176db when others were several db below this. AND this was done WITHOUT a factory sponsor on a budget of less than $25000 when the closest competitor was factory sponsored by more than one manufacturer and on a rough budget of about 1/4 million. We didn't get to replace our drivers or amps every run since we were not factory sponsored. The system was made to work and to last.
(In my best Irish accent...) Surrrre, surrre...Mr. Bubbles...whatever you say.
Mr. Bubbles
yeah i got that name for my bubbly fu@&!N personality. Fits pretty well doesn't it.Why did you refer to the cabinet design as "DK's "monocoque"?
Just tryin to give the "god" some credit.What do you mean by "if they weren't using 6.5" active drivers they would never hold up"? It appears that you are saying that Polk needed to use small drivers because the allegedly "poor" cabinets could not withstand the pounding from larger drivers. Using a larger number of smaller drivers can be more sonically advantageous than a single larger driver.
That is exactly what I meant. Smaller driver are definitely more advantageous for accuracy and sound quality. but they can not produce the pressures of large drivers. Sure the SRS's, 1.2's, and 1.2TL's have the cone area of an 18 but with very little excursion and even less motor strength. Don't get me wrong they sound awesome and the cabinets are adequate for the drivers installed in them but the build quality on the ones I have seen sucks.Well, common sense should indicate that if Ms. Yarbor wanted her "suitable replacement" comment to include drivers, she would have said that. She had the "driver" comment in bold all-capital type and the "components" comment later in normal type. This letter was written sometime in 1988 for the 1989 Field Service Manual. I don't recall that there were issues with driver availability during the time this was written. There is nothing in the manual about substituting one driver with another. Sometimes there were issues with sourcing electronic components (polyswitches, capacitors, etc.) and connectors.
You have some of that? You read it one way i read it another. same text. I'm sure you're right though.
laugh all you want with your Family cartoons, I have stated many times on these forums that I am the one trying to learn here, you are apparently the resident book of knowledge. My background is not in home audio and I am trying to gain what knowledge I can. I have made that plain so your cartoon doesn't seem to work here. But hey laugh all you want. If you ever come to South Carolina, look me up. Maybe we can have a beer and discuss things like real men.
I almost forgot, if you wish to respond to this again, fine. I am growing tired of the BS so I will let you have the last word as any "god" should be able to. I will not respond to you on this matter again.If con is the opposite of pro, is Congress the opposite of Progress?!
Again, Mr. Oliver Bubbles, I await your new and improved SDA's for the 22nd Century. Please right all the wrongs Polk did when offering these to the public. Please build a worthy cabinet.
Man the guy i bought these from was right; there are some fu@$in idiots around this forum. There are also some decent people too. Joe and a few others appear to be some of the latter. The rest of you dumba$$es please treat me like you are treating Audio and ignore me.If con is the opposite of pro, is Congress the opposite of Progress?!
oliverbubbles wrote: »Man the guy i bought these from was right; there are some fu@$in idiots around this forum. There are also some decent people too. Joe and a few others appear to be some of the latter. The rest of you dumba$$es please treat me like you are treating Audio and ignore me.
Really ...Mr. Bubbles, swearing and vulgar namecalling on a family forum such as ours? It's very unbecoming.oliverbubbles wrote: »yeah i got that name for my bubbly fu@&!N personality. Fits pretty well doesn't it.
No. Not lately.oliverbubbles wrote: »Don't get me wrong they sound awesome and the cabinets are adequate for the drivers installed in them but the build quality on the ones I have seen sucks.
Yeah, I've seen some messed up SDA's with messed up cabinets...due to owner abuse. The cabinets of my SRS's and 1.2TL's are very good. Of the SDA's I have owned, the only ones where I had some issue with the cabinets were my CRS+'s. That was due to the "crumbly" nature of the particle board when drilling them to install steel driver retaining rings.oliverbubbles wrote: »But hey laugh all you want. If you ever come to South Carolina, look me up. Maybe we can have a beer and discuss things like real men.
Based on your conduct on this forum, I assume "discussing things like real men" includes lots of insults and cursing. Therefore, I will politely decline.oliverbubbles wrote: »I almost forgot, if you wish to respond to this again, fine. I am growing tired of the BS so I will let you have the last word as any "god" should be able to. I will not respond to you on this matter again.
OK. Good night Mr. Bubbles. It was nice chatting with you.Proud and loyal citizen of the Digital Domain and Solid State Country! -
First of all you guys are mad geniuses as I dont understand half of what you all are talking about.
Second of all you guys are all crazed for getting into this heated discussion.
Third I am crazier for reading this entire thread.
Keep it up!!:biggrin::biggrin:I got static in my head
The reflected sound of everything -
I'm really sorry I was busy elsewhere and missed this...entertaining discussion today. Someone should have told me to get online and bring the popcorn. Backing up several hours:DarqueKnight wrote: »I have attached a copy of the forward statement from the 1989 Polk Audio In Field Technical Manual. Warranty Manager Helen Yarbor states, in all caps (which is the written equivalent of screaming):
The key point that I think DK has made several times is that if someone wants to make changes to vintage Polk speakers, Polk is remarkably supportive of inquiries. In fact, when I inquired about a month ago about RD0198-1 and MW65xx availability, the response came from...Ms. Yarbor. There are few companies that still have the same (quite knowledgeable) people dealing with issues 20+ years later...so regardless of any experience or degree I might have, I'd personally tend to ask Polk for at least a review of any significant modification plans (beyond replacing specific capacitors/resistors with updated high-quality components of the same impedance).
--CNWDICurrent polk speakers:
Family room 5.1: TC265i R/L, VM10 Center, RC65i surrounds (couldn't match the TCs)
Basement non-dedicated 7.1 HT: SDA-CRS+ R/L, 255c-LS Center, LSiFX surrounds, RC80i in-ceiling rear surround, plus Wharfedale 12" sub (some day I'll get around to building 15" F-20 sub). -
For Mr. Bubbles (before I put you on ignore), the following may help you determine why you can't arbitrarily switch crossovers:
Driver ........ Q ........ BL .... Compliance .... DC Res ........... Fs ...
MW6501 - 1.470 - 5.96 N - 3.250 E 3N/M - 7.750 Ohms - 31 Hertz
MW6502 - 1.970 - 5.16 N - 1.470 E 3N/M - 3.520 Ohms - 44 Hertz
MW6503 - 1.820 - 5.24 N - 3.550 E 3N/M - 6.540 Ohms - 29 Hertz
MW6509 - 2.100 - 4.57 N - 3.540 E 3N/M - 8.970 Ohms - 30 Hertz
MW6510 - 1.390 - 6.32 N - 3.410 E 3N/M - 6.570 Ohms - 31 Hertz
MW6511 - 1.405 - 4.34 N - 3.496 E 3N/M - 3.130 Ohms - 29 Hertz
MW6512 - 1.905 - 4.99 N - 1.588 E 3N/M - 3.466 Ohms - 40 Hertz
Cabinet design/bracing/volume and the exact version of the passive used also come into play.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
oliverbubbles, I'd like to commend you on your OP and your effort to improve your speakers (however, it is very unfortunate that the thread turned out the way it is now. Who's guilty, I don't really care and will not comment).
The above quote is key, there are so many variables (mechanical, electrical, physical) that will make a speaker and this is best left to the engineers and the manufacturer that created a specific product. I really feel it would be in your interest to trust and seek Polk advices on mods you want to achieve as they can provide you with some valuable insight.There are design rules and which must be respected during the course of a modification.
I do not know you so not sure where you would put your self but;
There are hobbyists:
"An activity or interest pursued outside one's regular occupation and engaged in primarily for pleasure." IMHO, a hobbyist has some skills, abilities and knowledge however, is not a specialist per say.
There are technicians: 1. A person employed to look after technical equipment or do practical work in a laboratory.
2. An expert in the practical application of a science.
However, IMHO the technician while having some skills they are somewhat limited to repair, maintenance and proven upgrades that are provided and approved by higher technical expertise.
Technologist: A specialist in technology. IMHO this is the guy that would attempt to do the type of modifications you are trying to attempt however; he would work closely and under the guidance of the engineer responsible for the project.
Engineer: A person who designs, builds, or maintains... IMHO, he is the creator (the god as you like to point out) that one (hobbyist, technician, technologist) would go to for guidance for any changes in design (IMHO, even a serious engineer would often refer to the creator of the design if intending to modify existing design).
Now, I am in no way trying to pick on you but 1st just want to know where you locate your self in this ladder? Secondly, IMHO it seems you are missing/miss-understanding the critical aspect of playing with the original value of each components of a design.
Personally, I am and I stop at the technician level. I know my abilities, what I can perform and exactly where I should stop and seek advices from the manufacturer. No big deal in most cases playing with series/parallel as long as the original values remain the same. No biggy replacing parts with better quality/newer technology as long as the original design is respected. No problem repairing and so on however, when it comes to altering the original design I realize this is not my place and if I have an idea I think that can improve or believe it will not affect the end result, I will not take my assumption for granted and will dare ask for advices at the engineering level. IMHO, you are to be commended for your effort to improve your speakers but IMHO, you would greatly benefit from seeking the creator (Polk) of your speakers.
Again, I commend you for your post, what you achieved so far and what you are actually trying to accomplish. Please keep us posted on your progress as I am very interested to see where this is leading you (good or bad). Life is a learning curve and I can definitely see this is exactly what you are doing/achieving.DARE TO SOAR:
oliverbubbles wrote: »I apologize Joe, I do see that and i now see where the confusion is coming in. I have been describing this in "effective" terms as compared to each other instead of actual terms as you are here. That is my fault and i am sorry to have confused you. i may have also confised you in my answer to your previous question. so let me rephrase my previous answer; yes I am making adjustments to compensate for this actual difference.
No problem at all, I just wanted you to look at the whole picture and not separate as you had been.
I apologize if I came off angry. I will admit I was getting perturbed but only because my explanation was being missed. Probably why I don't have children. :biggrin:
Your idea for a possible fix may in fact work so again I say good luck.
