EXIII 6x9 to Momo MMC 6x9 Momo = Less Bass?
Systems
Systems Posts: 14,873
edited March 2004 in Car Audio & Electronics
I recently upgraded from the EXIII 6x9's to the new Momo MMC 6x9's. I used the supplied crossover. Mounting position is exactly the same and the EXIII's. Now I have substantially less bass than I had with the EXIII's. Kick drums no longer kick!
Im positive that they are not out of phase, as bass does not improve when panning from right to left. Im really disappointed by the sound of these. They are much cleaner on top, but the low end just doesn't sound exciting at all. Does anyone have any ideas or know why the bass is so much less than the EXIII's I had before. It almost sounds like its out of phase, but im positive its not.
Head is Kenwood Excelon X-569
Amp is Fosgate Power 400a4
Testing
Testing
Testing
  • Systems
    edited March 2004
    Reverse before or after the crossover?
    if after the crossover...
    On the driver only? or driver and tweeter?
    Is this mentioned in the manual?
    Testing
    Testing
    Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited March 2004
    *scratching head* ... ummm... if he does it to both drivers, assuming they weren't out of phase to begin with (with respect to the fronts) how's that going to help? or is that the point? [that the crossover being as it is would cause the rear 6x9's to be out of phase with most other speakers using another or no crossover] ??
    The Artist formerly known as PoweredByDodge
  • Jstas
    Jstas Posts: 14,985
    edited March 2004
    I was thinking about that too but, if the crossovers reverse phase and then send the signal to the speakers then if you hook them up like the front speakers, the rear speakers will be out of phase.
    Reverse the phase by wiring the crossovers to the signal source backwards and the crossovers switch the phase and end up matching the front speakers phase. Matching phase means no cancelled bass and lotsa noise from 6x9's.
    Did that make sense or did I get it all wrong again?
    Expert Moron Extraordinaire
  • exalted512
    exalted512 Posts: 10,735
    edited March 2004
    phasing and wiring DVC subs always confuses me...
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2004
    -Cody
    Dude, Ive been lost, I just didnt want to say anything in case I was the only one! :D
