Adcom 565 Pre Amp Selector Switch Cleaning
[Deleted User]
[Deleted User] Posts: 1,225
edited September 2011 in Electronics
A pal of mine was wondering what is a good forum recommended contact cleaner ? Also, is there a preferred method for cleaning a sealed selector switch on an Adcom 565 Pre-Amp ? Thanks in advance. :cool:
    heiney9 Posts: 25,396
    DeOxit Fader Lube or DeOxit cleaner.
    I just look for any opening in the pot or try and spray it down in the shaft and let it penetrate, then move the switch/pot around several times. If you end up soaking it (very easy to do) let it dry before applying any power.
  • [Deleted User]
    H,
    Once again, many thanks. Cheers. :cool:
