2.0 setup question?
1QWK510
1QWK510 Posts: 19
edited September 2011 in Speakers
I just ordered a set of rti a1's and was wondering if I can run them in pure direct mode or leave them set to large without damaging them . The problem is I can't use audyssey if I change them from large to small after calibration because it automatically add a sub which I do not have yet.
Post edited by 1QWK510 on
  • falconcry72
    falconcry72 Posts: 3,580
    What receiver are you using to run them?
    Being set to "full range" or "large" or "pure direct" will not inherently damage the speakers; they can take whatever you throw at them, as long as it's good, clean power. Under-powering them at a high volume, whether set to "large" or not, could potentially damage them, as it could any speaker.
    BTW, welcome to CP! :smile:
    There's a ton of good info and helpful folks 'round these parts.
  • 1QWK510
    1QWK510 Posts: 19
  • rebuy
    rebuy Posts: 694
    Run them as full. Listen to them for awhile before making a judgement. They give give a pretty good spectrum of sound for a small speaker.
