2.0 setup question?
I just ordered a set of rti a1's and was wondering if I can run them in pure direct mode or leave them set to large without damaging them . The problem is I can't use audyssey if I change them from large to small after calibration because it automatically add a sub which I do not have yet.
Post edited by 1QWK510 on
What receiver are you using to run them?
Being set to "full range" or "large" or "pure direct" will not inherently damage the speakers; they can take whatever you throw at them, as long as it's good, clean power. Under-powering them at a high volume, whether set to "large" or not, could potentially damage them, as it could any speaker.
BTW, welcome to CP!
There's a ton of good info and helpful folks 'round these parts.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Denon avr1712
Run them as full. Listen to them for awhile before making a judgement. They give give a pretty good spectrum of sound for a small speaker.
