Got new speakers, now just need a receiver
Hey guys, so i just got a pair of polk audio monitor 40 series II speakers, and i love them. But currently i have this small 100 w receiver that isnt even working anymore. So im looking to get something that can really power these babies. I got the speakers for around 150, so im looking to spend around the same maybe a little less for a receiver, if possible. So like 100-150, but i dont really know much about this stuff, so im here asking for some help/advice on what i should get =]
Post edited by kobyjd on
I dont think your going to find anything in that price range. $300 and used could get you something desent.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
How many watts should i really be looking at.
Get a rotel 1052 stereo receiver and it will make them puppies sing but that would cost $350
Ive found some 500 watt receivers on ebay for 100-150, but im not sure if thats what i need.
350 is a little outa my price range, im really only going to be using these for music blasting -
Don't worry about the advertised watts, 90% are BS anyways. It plays a small factor, but not much. I'd look at s/n ratio, weight, harmonic distortion, current, advertised watts vs actual watts with all channels driven. The brand also plays a big factor into the sound, every brand sound different. Features are important as well, do u need 3d, hdmi, video upconversion, ipod control, zones 2 or 3, setup mic etc. Not trying to overwhelm you but a lot of people get blinded by how many watts and end up with a receiver that sounds like crap.
ok post what exactly your found on ebay. Just because it says 500w does not mean you get that. If its a 5.1 thats 500watts split between 5 channels and even THEN youll never get 100wpc, youd be lucky to hit 40wpc.
Where exactly are you located at? Im actually selling a vsx-1020k thats less then 9 months old, if your interested I could give you a decent deal on it. And that way youll have a NEWer receiver that will actually give you decent sound and have a lot of the bells and whistlesHome Theater Setup- Receiver - Onkyo TX-RZ1100
- Mains - Polk RTi A9's
- External Amps - Outlaw 2200 Monoblocks for L/R/C
- Center - Polk CSiA6
- Side Surrounds - Polk FXiA6's
- Atmos - 4 Polk 80F/X RT's
- Sub - SVS PC-4000
- T.V. - LG OLED65C7P
I agree with Dskip...a cheap Sherwood 2 channel can be had for less than 100 new. Should drive them fine if you're on a budget.
http://www.jr.com/sherwood/pe/SHE_RX4105/
If you can afford a bit more. Check out a Harman Kardon HK 3390 for a little over 200.
Or an Onkyo TX-8555. Both of these have plenty of power for a set of M-40s!
You'd be better off with the HK or the Onkyo...better sound and sub-outs so you can punch up the bass. Everything above is 2 or 2.1 channel only. No HT!
Check out Amazon for these or do a search.
Welcome to Club Polk!
Good Luck!
Ok, it might not be great but it's around 200 at Radio Shack.
They sell a Yamaha Home theater receiver for that price.
It's a starter.
Good luck. -
i have an Onkyo 705 FS in the FM
http://www.polkaudio.com/forums/showthread.php?123864-Pioneer-elite-SC-07-BDP-23fd-Onkyo-705&highlight=mole%27mole' -
FWIW, the xx5 series is highly regarded as having a great amp section. I'll disagree with everyones sugestions so far though, I think this is a job for craigslist! Have you tried CL yet kobyjd? In your price range you might be suprised with what you find, where are you located?
Right now im in bloomington Indiana -
Thank you guys for all the input! You have all been extremely helpful
