Got new speakers, now just need a receiver
edited September 2011 in Speakers
Hey guys, so i just got a pair of polk audio monitor 40 series II speakers, and i love them. But currently i have this small 100 w receiver that isnt even working anymore. So im looking to get something that can really power these babies. I got the speakers for around 150, so im looking to spend around the same maybe a little less for a receiver, if possible. So like 100-150, but i dont really know much about this stuff, so im here asking for some help/advice on what i should get =]
Post edited by kobyjd on
Welcome!
    I dont think your going to find anything in that price range. $300 and used could get you something desent.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    How many watts should i really be looking at.
    Get a rotel 1052 stereo receiver and it will make them puppies sing but that would cost $350
    Ive found some 500 watt receivers on ebay for 100-150, but im not sure if thats what i need.
    350 is a little outa my price range, im really only going to be using these for music blasting
    Don't worry about the advertised watts, 90% are BS anyways. It plays a small factor, but not much. I'd look at s/n ratio, weight, harmonic distortion, current, advertised watts vs actual watts with all channels driven. The brand also plays a big factor into the sound, every brand sound different. Features are important as well, do u need 3d, hdmi, video upconversion, ipod control, zones 2 or 3, setup mic etc. Not trying to overwhelm you but a lot of people get blinded by how many watts and end up with a receiver that sounds like crap.
    ok post what exactly your found on ebay. Just because it says 500w does not mean you get that. If its a 5.1 thats 500watts split between 5 channels and even THEN youll never get 100wpc, youd be lucky to hit 40wpc.
    Where exactly are you located at? Im actually selling a vsx-1020k thats less then 9 months old, if your interested I could give you a decent deal on it. And that way youll have a NEWer receiver that will actually give you decent sound and have a lot of the bells and whistles
    Home Theater Setup
    • Receiver - Onkyo TX-RZ1100
    • Mains - Polk RTi A9's
    • External Amps - Outlaw 2200 Monoblocks for L/R/C
    • Center - Polk CSiA6
    • Side Surrounds - Polk FXiA6's
    • Atmos - 4 Polk 80F/X RT's
    • Sub - SVS PC-4000
    • T.V. - LG OLED65C7P
    I agree with Dskip...a cheap Sherwood 2 channel can be had for less than 100 new. Should drive them fine if you're on a budget.
    http://www.jr.com/sherwood/pe/SHE_RX4105/
    If you can afford a bit more. Check out a Harman Kardon HK 3390 for a little over 200.
    Or an Onkyo TX-8555. Both of these have plenty of power for a set of M-40s!
    You'd be better off with the HK or the Onkyo...better sound and sub-outs so you can punch up the bass. Everything above is 2 or 2.1 channel only. No HT!
    Check out Amazon for these or do a search.
    Welcome to Club Polk!
    Good Luck!
    cnh
    Ok, it might not be great but it's around 200 at Radio Shack.
    They sell a Yamaha Home theater receiver for that price.
    It's a starter.
    Good luck.
    FWIW, the xx5 series is highly regarded as having a great amp section. I'll disagree with everyones sugestions so far though, I think this is a job for craigslist! Have you tried CL yet kobyjd? In your price range you might be suprised with what you find, where are you located?
    Theheadsn wrote: »
    Right now im in bloomington Indiana
    Thank you guys for all the input! You have all been extremely helpful
Welcome!
Welcome!
