Design Off the MM10 and Warranty Question For POLK CSR Popping Noise
Systems
Systems Posts: 14,872
edited March 2004 in Car Subwoofer Talk
Anyways you guys know how the speaker the MM10s are they hit the grill with some good BASs well I took out the grill and I thought the MM10s had other screws holding the speakers in place besides the Grill Screws.
I had like 3 screws on the Polk bolts the Allen Screws.
Today I find out after countless off hours that the grill bolts are the main bolts hold the speaker down I am guessing that's why I had the popping noise also when I screwed the Allen Screws it came out the other side with peace's off the box scraps because the screw came out the other side I know POLK is aware off this issue and does know this and hasn't corrected the problem until now.
Testing
Testing
Testing
