Design Off the MM10 and Warranty Question For POLK CSR Popping Noise
Systems
Anyways you guys know how the speaker the MM10s are they hit the grill with some good BASs well I took out the grill and I thought the MM10s had other screws holding the speakers in place besides the Grill Screws.
I had like 3 screws on the Polk bolts the Allen Screws.
Today I find out after countless off hours that the grill bolts are the main bolts hold the speaker down I am guessing that's why I had the popping noise also when I screwed the Allen Screws it came out the other side with peace's off the box scraps because the screw came out the other side I know POLK is aware off this issue and does know this and hasn't corrected the problem until now.
Testing
Testing
Testing
Testing
Testing
my grille is screwed in with the same screws my subs are screwed in with, ive never had a problem...
Someone understand what I am talking aboutTesting
Testing
Testing -
Translate it into English and we might be able to.
