Know anything about EPI Speakers?
mdaudioguy
I saw some EPI Time/Energy Monitor 1 Speakers on CL.... What do you think? Would they rock my garage?
Here's some info on them:
http://www.humanspeakers.com/e/epi-temon1.htm
Post edited by mdaudioguy on
I would give them a fair shake in the house, just for giggles.
I've got a pair of M50's that sound absolutely lovely. I had them at PF '10, and several people were quite surprised at the quality of sound coming from them (I think mostly because they're ugly as sin).
PS- Humanspeakers.com is a great resource... he's got equivalents of almost all the drivers available, even for my M50's.Ludicrous gibs! -
Thanks. It's good to hear that they may at least be listenable. I have no need for them in the house, but basically, I'm looking to fill a space in the garage, and these would fit the bill (size-wise). I was looking for some Klipsch KG 4.2s, which I'm assuming might be a better speaker, but they'll probably run me a bit more.
1987 is close to the time that EPI starts to go down the drain. But these may be on the good side of the cusp. Don't know.
I have a set of early bookshelves (EPI 100Vs) that can pretty much compete with most of their competitors in that time period. A nice set.
A friend has some EPI T/E 360s that can not only rock your garage but would make fabulous primary speakers for a two channel system. Among the best I've heard from the mid '80s. A real sleeper.
But 'neither' of these uses a 'horn' which is what your speakers have? They use various versions of the famous Air Spring inverted or the latter dome tweeter. Great highs. IMHO.
Here's a link for your speakers. They look big and loud enough!
Thanks! Btw, that's the link I put in my first post...1987 is close to the time that EPI starts to go down the drain. But these may be on the good side of the cusp. Don't know.
cnh
mdaudioguy wrote: »Thanks! Btw, that's the link I put in my first post...
Sorry. I'm spacing out this morning! More coffee is in order.
In any case. If I could find the T/E 360s in good shape, they'd be mine tomorrow. Your units may also be quite good.
Keep us posted!
