Mid-Fi to Hi-Fi decesions???
madmax
madmax Posts: 12,434
Recently I've found myself more and more frustrated by this hobby. On the Preamp I have the choice of switching in the output caps or not, high or low gain, high or low impedence output. Many choices of tube stages, cover on or off, aftermarket power cables, which interconnects to use, higher or lower output level to my amp... The turntable offers hundreds of choices of cartridges, hundreds of setup choices, weight, azmuth, cleaning supplies, brushes, cleaning methods, antistatic methods, etc... The CD could be of 50+ configureations between transport and dac, output polarity, options for transmission, power supply... The speakers can be optimised for bi-wire, bi-amp, diffraction techniques, positioning, room dampening techniques, etc... The power can be conditioned in many different ways, the power cables can be swapped around, There are spikes, isolation pods, etc...
I'm just tired...
madmax
Vinyl, the final frontier...
  • HBombToo
    HBombToo Posts: 5,256
    edited March 2004
    I'm very happy living in ignorance. Thak God I don't know that I don't know:p
    HBomb
    ***WAREMTAE***
    F1nut Posts: 52,001
    edited March 2004
    MadMax,
    It's simple really, you have too much gear. So, I'm going to do you a favor and take some of it off your hands........:D
    Your good friend,
    F1
  • madmax
    edited March 2004
    What is really bad is that I could go on for hours... There is one combination out of 4379487298374329837429 which will sound best in my room! Which one is it?
    madmax
  • amulford
    amulford Posts: 5,020
    edited March 2004
    4379487298374329837430:D
  • Tour2ma
    Tour2ma Posts: 10,177
    edited March 2004
    That's one possible answer.... But my guess would be #2. I think you skipped it... :p
    More later,
    Tour...
    Vox Copuli
