Pair of quality 4"X6" 8-ohm 2-way speakers
inspiredsports
I just purchased a nice 1961 Akai 1720-W Reel to Reel, but the on-board speakers leave a bit to be desired in that they are just single cone.
I'm looking for a nice quality pair of 2-way (or 3-way) speakers to squeeze a bit more sound out of it.
Speakers must be 8-ohm as the output transistors in this unit can't handle 4-ohm speakers.
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
NAD SS rigs w/mods
GIK panels
Post edited by inspiredsports on
I know someone has to have some take-outs lying around collecting dust from a car they upgraded.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
This might be harder than it seems since I think just about every aftermarket 4x6 for car audio would be 4 ohm, Not sure about the basic OEM speakers, but I believe many of the better OEM systems have varied impedences for each driver.2 Channel
Polk SDA SRS, Nakamichi Pa-5 Preamp, PA-7 Amp, Shenda (Jolida) SD100S CD Player (Sylvania Gold Brand 5751 & Amperex Holland, Orange Globe 12au7 tubes).
Home Theatre
Onkyo SR707, Samsung Blu Ray,Sony 400 Disc DVD Changer, Sony 46" LCD (Model?)
Speakers: Front L/R: JBL L7, Center: JBL LC1, Surround: TBD (likely JBL L1)
Car: Clarion 9255-DRX, Adcom GFA 4702, GFA 4404, Pioneer TS-A1702c (Front and Rear), 2 Boston Acoustics 12.5LF subs -
adcomcyclone wrote: »This might be harder than it seems since I think just about every aftermarket 4x6 for car audio would be 4 ohm, Not sure about the basic OEM speakers, but I believe many of the better OEM systems have varied impedences for each driver.
From what I can tell, you are correct; almost all new 4x6 systems are 4-ohm.
I may have to go to an auto recycler and look through some older cars.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
I guess I could just add a 12 watt Mills 4-ohm resistor in series to a 4-ohm speaker to present 8-ohms to the amp?VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
inspiredsports wrote: »I guess I could just add a 12 watt Mills 4-ohm resistor in series to a 4-ohm speaker to present 8-ohms to the amp?
Another option would be to make a 4x6 plate, cut a 4" hole in the middle, and run a 4" round full range 8 ohm in them.
Tang Band and Dayton Audio makes some decent 4" 8ohm full range speakers to name a couple.
I did it in the dash of a Chevy S10 that had 4x6 holes in the dash.
I bought some adapters and used 4" round JL Audio speakers in those locations.Testing
Testing
Testing -
That's a good idea, and maybe I don't have the right take on this, but my thought was that a 2-way speaker would sound better than a full-range speaker.
Actually, the single-cone full-range 4X6 Akai labelled speakers in the unit are very good.
I just thought high frequencies would sound better coming out of a 1" tweeter versus a 4" round or 4X6" oval single-cone driver.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
inspiredsports wrote: »That's a good idea, and maybe I don't have the right take on this, but my thought was that a 2-way speaker would sound better than a full-range speaker.
http://www.youtube.com/watch?v=JiMnRaUzfog&feature=player_detailpage
http://www.youtube.com/watch?v=DGHg1aTeTOQ&feature=player_detailpage
http://www.youtube.com/watch?v=7gR1-UiziSw&feature=player_detailpageTesting
Testing
Testing -
Well, I just confirmed the speakers in the 1720 are 5X7's instead of 4X6's.
There's enough room in there I might just enlarge the hole and toss in a Polk MW and an RDO-198 on each side :biggrin:VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels
