Pair of quality 4"X6" 8-ohm 2-way speakers
inspiredsports
inspiredsports Posts: 5,501
edited September 2011 in Wanted (WTB) Classifieds
I just purchased a nice 1961 Akai 1720-W Reel to Reel, but the on-board speakers leave a bit to be desired in that they are just single cone.
I'm looking for a nice quality pair of 2-way (or 3-way) speakers to squeeze a bit more sound out of it.
Speakers must be 8-ohm as the output transistors in this unit can't handle 4-ohm speakers.
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
Post edited by inspiredsports on
  • inspiredsports
    I know someone has to have some take-outs lying around collecting dust from a car they upgraded.
    NAD SS rigs w/mods
    GIK panels
  • adcomcyclone
    adcomcyclone Posts: 49
    This might be harder than it seems since I think just about every aftermarket 4x6 for car audio would be 4 ohm, Not sure about the basic OEM speakers, but I believe many of the better OEM systems have varied impedences for each driver.
    Polk SDA SRS, Nakamichi Pa-5 Preamp, PA-7 Amp, Shenda (Jolida) SD100S CD Player (Sylvania Gold Brand 5751 & Amperex Holland, Orange Globe 12au7 tubes).
    Home Theatre
    Onkyo SR707, Samsung Blu Ray,Sony 400 Disc DVD Changer, Sony 46" LCD (Model?)
    Speakers: Front L/R: JBL L7, Center: JBL LC1, Surround: TBD (likely JBL L1)
    Car: Clarion 9255-DRX, Adcom GFA 4702, GFA 4404, Pioneer TS-A1702c (Front and Rear), 2 Boston Acoustics 12.5LF subs
  • inspiredsports
    From what I can tell, you are correct; almost all new 4x6 systems are 4-ohm.
    I may have to go to an auto recycler and look through some older cars.
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    I guess I could just add a 12 watt Mills 4-ohm resistor in series to a 4-ohm speaker to present 8-ohms to the amp?
    NAD SS rigs w/mods
    GIK panels
  • Systems
    Systems Posts: 14,873
    Another option would be to make a 4x6 plate, cut a 4" hole in the middle, and run a 4" round full range 8 ohm in them.
    Tang Band and Dayton Audio makes some decent 4" 8ohm full range speakers to name a couple.
    I did it in the dash of a Chevy S10 that had 4x6 holes in the dash.
    I bought some adapters and used 4" round JL Audio speakers in those locations.
    Testing
    Testing
    Testing
  • Systems
    Like this:
    a10h4Aj1tHArD7SHIhtR1kLLj2iO9kzmWS710nFwDZh3jdnXTSuQ0aIYWckL-g02tS62aFdfBk-drcyfpNhlyJZgdUs_bBmCBIbZywRAcyZkI1IwWY93yYiC5ivGpXfUr3c-dthaRrbjGT2WeEvf9SQT3lEK-ZB-eySWbwGz501JSfaF2Uzrry1U-WxpBuvW0VrKT_zO_LzdtPnaNoR5Zwm0auutlaPk1ZrQnahE_is101Etwkjz5t8ofyEMfquCXxYV7eL6eDsRfuMhME8XysU41GHycjj4N0sI
    Testing
    Testing
    Testing
  • inspiredsports
    pepster wrote: »
    That's a good idea, and maybe I don't have the right take on this, but my thought was that a 2-way speaker would sound better than a full-range speaker.
    Actually, the single-cone full-range 4X6 Akai labelled speakers in the unit are very good.
    I just thought high frequencies would sound better coming out of a 1" tweeter versus a 4" round or 4X6" oval single-cone driver.
    NAD SS rigs w/mods
    GIK panels
  • Systems
    http://www.youtube.com/watch?v=JiMnRaUzfog&feature=player_detailpage
    http://www.youtube.com/watch?v=DGHg1aTeTOQ&feature=player_detailpage
    http://www.youtube.com/watch?v=7gR1-UiziSw&feature=player_detailpage
    Testing
    Testing
    Testing
  • inspiredsports
    Well, I just confirmed the speakers in the 1720 are 5X7's instead of 4X6's.
    There's enough room in there I might just enlarge the hole and toss in a Polk MW and an RDO-198 on each side :biggrin:
    NAD SS rigs w/mods
    GIK panels
