Psw110
what are the proper settings for the 'phase' and 'power' switches on this model? the manual doesn't mention them
Post edited by mattkinney60 on
  • larry777
    larry777 Posts: 480
    edited September 2011
    If your sub is on the same side of your room as your front L & R speakers then set your phase switch at 0 degrees. Your power switch should be set to Auto so the sub cuts in when called for. It can also be set to ON if you want to keep it fired up all the time, although it will still only output sound when the signal needs a sub response.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
