Psw110
mattkinney60
what are the proper settings for the 'phase' and 'power' switches on this model? the manual doesn't mention them
Post edited by mattkinney60 on
If your sub is on the same side of your room as your front L & R speakers then set your phase switch at 0 degrees. Your power switch should be set to Auto so the sub cuts in when called for. It can also be set to ON if you want to keep it fired up all the time, although it will still only output sound when the signal needs a sub response.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects
