Sub woofer match
Rataxes
hello
I would like to add a sub woofer to my speakers set , however , I do not know which one is matching the best , and I hope that someone could recommend me one. (POLK only
The set includes front speakers - TSi 400 , and a CS10 center in between them , in addition there's a pair of TSi100 in the back .
Receiver is Pioneer VSX - 521 k
Thank you for your help !
Post edited by Rataxes on
looks like your speaker goes down to 44 hertz the psw 125 goes down to 32 to 80 hertz so it should fill the void nicely , you just gotta be sure you like the way the cabinet looks and fits in your location , as with any subwoofer I recomend buying a bigger more powerfull unit because you can always turn it down but if it cant make the amount of bass you like there is no turning up a small sub once its maxed .
I have been building subs for 15 years and learned that lesson the hard way
I wouldn't take a manufacturers specs as gospel, your in room response will vary greatly as everyones rooms are different.HT SYSTEM-
lsi 9's -
Thank you all
Room is 15 X 10 -
in meters...
