Sub woofer match
Rataxes
Rataxes Posts: 5
hello
I would like to add a sub woofer to my speakers set , however , I do not know which one is matching the best , and I hope that someone could recommend me one. (POLK only :wink:)
The set includes front speakers - TSi 400 , and a CS10 center in between them , in addition there's a pair of TSi100 in the back .
Receiver is Pioneer VSX - 521 k
Thank you for your help ! :smile:
  • thsmith
    thsmith Posts: 6,082
    edited September 2011
  • 20hz
    20hz Posts: 636
    looks like your speaker goes down to 44 hertz the psw 125 goes down to 32 to 80 hertz so it should fill the void nicely , you just gotta be sure you like the way the cabinet looks and fits in your location , as with any subwoofer I recomend buying a bigger more powerfull unit because you can always turn it down but if it cant make the amount of bass you like there is no turning up a small sub once its maxed .
    I have been building subs for 15 years and learned that lesson the hard way :)
    I wouldn't take a manufacturers specs as gospel, your in room response will vary greatly as everyones rooms are different.
  • Rataxes
    Rataxes Posts: 5
    Thank you all
    Room is 15 X 10
  • Rataxes
    Rataxes Posts: 5
    in meters...
