Looking for good receiver for Polk Mon 70's
paulgj
paulgj Posts: 16
Hello,
I have a pair of Monitor 70's (Series II) and a PSW10 and am trying to find out what kind of receiver would be a good match for these speakers in a 2.1 configuration. I'm particularly concerned about getting enough power for these speakers and having good specs to drive them as well as possible without damaging them.
When looking at Receiver specs I see a lot of confusing info such as two sets of numbers for say "Front L/R" ratings", one will be say 80W+80W at 8 ohms and another at 110W+110W for 6 ohms at a different Khz rating. I'm still trying to figure out exactly what this means, but am trying to get an idea of what to look for and what to avoid :confused:
Also are there any particular features to look out for with regard to the Subwoofer connection on a receiver?
Any suggestions or tips, links etc. would be greatly appreciated.
-Paul
HK 3490, Pair Monitor 70's (series II), PSW505
Post edited by paulgj on
  • mantis
    mantis Posts: 17,377
    edited September 2011
    Do you plan on going with a full theater down the road? If so then look no further then Pioneer Elite VSX52 or VSX53. These receivers will power your monitor series speakers beautifully . Not to mention have the latest in technology and coolest things like Airplay and 3D.
    Even if 2.1 is all your going to use , this receiver sounds sweet for music and has plenty of dynamic range to make those Monitors sing.
    http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Elite+Receivers
    Dan
  • paulgj
    paulgj Posts: 16
    thanks Mantis, that's a little more than what I wanted to spend, sorry should have mentioned that (would like to kee below $500 if poss). Yeah, sound quality is more important that home theater stuff right now, mainly looking for just a good music listening experience, not too interested in hooking up to Blu-Ray or TV at this point but would consider in the future.
    What would be a min power rating that would be OK to use with these speakers?.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    Reported entire thread!
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • stangman67
    stangman67 Posts: 2,329
    This is a pretty smoking deal and will provide your monitor's with plenty of power.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16882115274
  • stangman67
    Or for more coin, http://www.newegg.com/Product/Product.aspx?Item=N82E16882115275
    Very robust internal amplifier
  • paulgj
    paulgj Posts: 16
    Thanks for the tips, I am interested mainly in music so I got the Harmon Kardon HK 3490.
  • stangman67
    Not a bad choice. HK's have notoriously had some of the beefiest internal amps too, so you'll be more than good on power
