What's the difference in these two Adcom DVD players?
Mr. Sharpe
Anything?
http://www.amazon.com/Adcom-GDV-870-Performace-Player-Upconversion/dp/B001503DT4/ref=sr_1_11?s=electronics&ie=UTF8&qid=1315194019&sr=1-11
http://www.amazon.com/Adcom-GDV-870-Definition-DVD-Audio-Player/dp/B000NWCOPY/ref=sr_1_15?s=electronics&ie=UTF8&qid=1315202943&sr=1-15
One is cheaper but sold by Home Electronics. I don't know what the difference is between the two. One says it's a high definition DVD audio/video player and the other says High Performace DVD Player with HD Upconversion but the model no.'s are the same.
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Post edited by Mr. Sharpe on
I actually found one review that said it had poor build quality.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Parasound HCA -1500a Amplifier -
Mr. Sharpe wrote: »I actually found one review that said it had poor build quality.
They are the same player, but the above quote sums up things nicely.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I have no experience with Adcom's DVD players but one negative review doesn't mean much to me.TO ERR IS HUMAN. TO FORGIVE IS CANINE.
For 300 bucks Id get a PS3- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
If it's the same model number, chances are they are one in the same. One might be a newer version of the same model though. Either way, curious as to why your looking at these when so many better options abound.HT SYSTEM-
lsi 9's -
I've seen one negative and one positive so that's why I asked.If it's the same model number, chances are they are one in the same. One might be a newer version of the same model though. Either way, curious as to why your looking at these when so many better options abound.
I understand that, I just came across it, but i can't find but two reviews on it so that tells me to stick with their amps and preamps.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
nooshinjohn wrote: »They are the same player, but the above quote sums up things nicely.
I got that for sure, it looks like this guy knew what he was talking about, the other review just said "looks pretty, plays good" short and to the point some what lolHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Mr. Sharpe wrote: »Anything?
one can be Refurbished!!! That is why the price can be lower.
Make it simple...Make it better! -
Does home electronics sell refurbished things? I will look on their site tonight!Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Mr. Sharpe wrote: »Does home electronics sell refurbished things? I will look on their site tonight!
hahahaha sure! I have seen a lot! some stores (small) they take the tag that said "refurbished" and they sell them like new. even in eBay you can find some "refurbished" Polk speakers at lower price.Make it simple...Make it better! -
Unless you got a line on a used one for a great price, in that range you should be able to find a used Oppo 83.
Oppo seems like the very best possible choice for a blu ray player or any player to me since there are very little to no negative reviews on them.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
