speaker question
Can I replace an 8ohm stock speaker with a polk 4ohm speaker without damaging speaker or the stock radio?
The quick answer is no. Your crossover was designed for a particular impedance, as well as your radio. Stick to original specifications.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Try posting in the Car Audio forums, you're in the home audio forums. You'll get more help there.
