Best car rental deals?
obieone
obieone Posts: 5,077
edited September 2011 in The Clubhouse
I'm trying to figure out who, if any, rental co. has the best rates:confused:
And yes, I'm a member of AAA.
TIA
Post edited by obieone on
  • bobman1235
    bobman1235 Posts: 10,822
    It's the worst website in teh world, but I've gotten some really good deals off of here : http://www.rentalcodes.com/index.html
  • exalted512
    exalted512 Posts: 10,735
    Not exactly what you're asking...but good info to know anyway...
    9 times out of 10, your auto insurer covers your rental car...so dont buy the 'extra coverage'.
    Also, make sure the car is clean when you get it. Had a friend of mine rent a car and it was dirty. They came back and all of a sudden the company pointed out all these dents and dings and chips that 'werent there before'...when all he did was drive it around town.
    So make sure the car is clean and you take note of all damages prior to leaving the lot.
    -Cody
  • obieone
    Thanks for the link Bob.
    And yes, I should def. do a walkaround b-4 signing anything.
  • Gadabout
    Gadabout Posts: 1,072
    AAA usually gets me better discounts on the weekends. The company I work for, their code seem to work better during the week.
    I usually rent form Hertz. You didn't mention when your renting. A good rule of thumb is the cheapest rental cars will be somewhere where they avoid the concession fees and other taxes. It won't be as convenient, and will take more time but it will be cheaper.
    For an overall rental cost comparison try using orbitz. Then go to the company specific site and see which discount works the best.
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • codyc1ark
    codyc1ark Posts: 2,538
    Avoid renting from airport locations, they usually have extra taxes, last time I rented out of O'Hare I got hit with something like an 18% airport tax. Cody is sort of right, if you carry full coverage on one of your own vehicles, it should extend to your rental. If you don't own or don't carry full coverage your SOL if you wreck it. He's very correct about the damages, make sure you walk around it with your rep and all the damaged areas are addressed before drive off.
  • obieone
    Yeah, I've done a little research, and found there are like an additional $100+ in fees to rent from an airport. Screw that!
    It seems tha Orbitz does have the best deals.
    I'm looking at renting a midsize, hopefully a Sonata. This car has piqued my interest, and a simple test drive around the block, prolly won't give me the full picture, so a road trip will kill 2 birds.
    My '02 S10 would most likely make the trip no problem, but I am curious about the Sonata, so...
  • brettw22
    brettw22 Posts: 7,623
    The sonata is not a midsize.....the elantra is.....when you go to pick it up sit there and ask them what the chances are that they upgrade you etc...and I think you'll have less luck getting upgraded at the smaller regional locations than the airport type of places.
    I drive the sonata all the time as a rental and the only complaint I have is that the front suspension is clunkier that that of toyota or honda. Drive over some choppy roads to see what I mean.
    tonyb Posts: 33,072
    obieone wrote: »
    Yeah, found that out the hard way on a trip to San Fran.
