Looking for a decent pair of monitor 12's
Roger5150
Putting together a small retro analog system and am looking for a pair of monitor 12's to round things out. Any leads greatly appreciated.
I can barely see the road from the heat comin off it
Post edited by Roger5150 on
Welcome to the Club!
Where are you located?
What is your budget for these speakers? -
Are you "stuck" on having that particular model ? BTW....Welcome!
Hello and thank you for the welcome. I am still using a pair of 5B's that I bought new in the 80's I want a similar speaker but in a floorstander The 12's seem to be the model that fits for me, same type of configuration but more drivers and hopefully not a budget buster.I am hoping to find a pair of these in the 300-350 neighborhood with the expectation that I will have to throw a little money at them. replacing drivers ext.
Thanks, RogerI can barely see the road from the heat comin off it -
BTW located in the Chicago areaI can barely see the road from the heat comin off it
welcome to CP.....
just incase...i have 2 sets of Monitor 10 that im not using.mole' -
Welcome to club polk Roger. 12s do come up from time to time. I very nice pair can fetch $175.
Owned a pair and liked them. You can upgrade the tweeters to RDO-198, polks new silk dome to replace the ones that can stock, a worth wild upgrade at 100 for the pair shipped from PA.Speakers: SDA-1C (most all the goodies)
Your best lead will be your local craigslist, the drivers in the older polk speakers don't travel well without first having the magnet's defective glue job reinforced, usually done with JB Weld or epoxy . It's better to pick them up personally and transport gently, then do the re-glue.
