LSI7 amp pairing
I just bought some LSI7's and from what I have read they really benefit from an amp. So amp shopping is the next thing. But first I had some questions maybe some of the "gurus" could chime in and help me understand.
1. The 7's specs say they are rated for an amp up to 150w/ch, is anything over 150w an overkill for these speakers? Are there pro or cons to higher wattage?
I see a lot of amps in the 200-300w range. Do I need to stay below 150w
2. Would an amp really be a significant improvement for this speaker?
Post edited by fyrn on
No, you don't need to stay below the "rated" wattage, but (obviously) you don't turn these things up to deafening volumes, either. LSis are about quality. A 200-300 watt amp would be fine with these.
Significant improvement over what? I ran a nice integrated amp with a pair of 7s, and the result was wonderful. 100 wpc into 4 ohms...
What are some of the amps you're considering? -
mdaudioguy wrote: »
I'm mainly looking at Emotiva (xpa3 or upa2) or a use parasound like HCA1000/1500
