Red Ring of Death on Xbox 360 - just out of Warranty!
So I find out that Microsoft has extended the warranty of these units to 3 years from the original purchase date, if you have the Red Ring of Death problem. The only thing is, my unit's warranty just expired on the 17th of last month (July) - 6 weeks out of warranty the unit fails!
Any suggestions on how to fix this myself?
Thanks in advance,
Serendipity
Thanks in advance,
Serendipity
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
The official 1 year warranty? Or the extended 3-year warranty for RROD failures?
My console failed after 3+ years.
That was my experience too.
Funny though, I ended up paying Dad back $350 for the Xbox, and he was the one who used it most! Same for the Wii console. Haha.
beat me to it.
Check Craigslist, there's always people on there who advertise they can fix them cheap.
The thing works now! I didn't even have to buy any thermal grease or anything like that... simply removing the screws, pressing down on the GPU until it stopped 'creaking', and then tightening the screws firmly made it work!
Awesome!
You should have put some thermal grease on while you had it apart...
Yeah but I saved 6 bucks... and fixed it myself!
Do it over with some thermal grease and you won't have to worry about it again.
You build your own computers right, you should have some handy anyway.
Boxed processors come with the thermal grease already applied.
I have never had to place thermal grease on any Intel CPU, and therefore never bought any.
A thin layer, just enough to fill in the gaps will really improve the efficiency of the cooling and extend the life of the processor. Definitely worth the extra trouble and time to do it properly. For PCs as well as the xbox.
I feel your pain but for the third time already.
