Receiver suggestion
nikhildeshmuk
Hi i recently brought Polk Audio RM6750 5.1 Channel Home Theater Speaker System can any one suggest me a good reciever($200-$300 range) which is compatible with this system!!
Thank you!!
Thank you!!
Post edited by nikhildeshmuk on
Thank you for you suggestion if you don't mind can you help me out choosing between the two options below
Insignia? - 450W 5.1-Ch. 3D Pass Through A/V Home Theater Receiver with Rocketboost Model: NS-R5101AHD-A
Yamaha - 675W 5.1-Ch. A/V Home Theater Receiver Model: RX-V371 -
The yamaha would probably be better.
I really do not like the tone of my Yamaha RXV-1700. When I was using it as a pre/pro and amp, and even now that the fronts are powered by a B&K, I finf the sound to be very thin on the low end (even with the bass jacked to +6db and tweaking the eq) and a tad bright. I wish I could get it out of the chain as it is really holding my system back, but it will have to wait.
[The Ever-Evolving System
LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
