Receiver suggestion
nikhildeshmuk
nikhildeshmuk Posts: 3
edited August 2011 in Electronics
Hi i recently brought Polk Audio RM6750 5.1 Channel Home Theater Speaker System can any one suggest me a good reciever($200-$300 range) which is compatible with this system!!
Thank you!!
Post edited by nikhildeshmuk on
  • nikhildeshmuk
    edited August 2011
    Thank you for you suggestion if you don't mind can you help me out choosing between the two options below
    Insignia? - 450W 5.1-Ch. 3D Pass Through A/V Home Theater Receiver with Rocketboost Model: NS-R5101AHD-A
    Yamaha - 675W 5.1-Ch. A/V Home Theater Receiver Model: RX-V371
  • cheezeitz51
    cheezeitz51 Posts: 14
    edited August 2011
    The yamaha would probably be better.
  • Jer.War
    Jer.War Posts: 180
    edited August 2011
    I really do not like the tone of my Yamaha RXV-1700. When I was using it as a pre/pro and amp, and even now that the fronts are powered by a B&K, I finf the sound to be very thin on the low end (even with the bass jacked to +6db and tweaking the eq) and a tad bright. I wish I could get it out of the chain as it is really holding my system back, but it will have to wait.
    [The Ever-Evolving System
    LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
