Any Bell'O rack owners? Danger Will Robinson!
John in MA
John in MA Posts: 1,010
edited September 2011 in The Clubhouse
Does Club Polk have any users of Bell'O racks? You might want to take steps to ensure this doesn't happen to you.
Disconnecting the speaker cables on my amp a few weeks ago and the lower shelf supports on my rack gave way and crashed to the floor. The amp's cables pulled on the preamp, and its shelf pulled down, which then PULLED EVERY OTHER SHELF DOWN. My entire system collapsed on my arm. I could barely pull it out from under all the equipment and I'm glad either me or the rig wasn't smashed up more.
It's a Bell'O AT-4203A, about 8 years old, the $650+ price of which doesn't seem appropriate at this point. These stupid shelf clips are made out of thin cast zinc (or something) and most of them appear to be deformed.
Total damage:
One bruised arm
One Kinergetics KCD-40 Platinum CDP with a scratched back panel
One Rotel RB-990BX power amp with a dented and squished top panel
One McIntosh C712 with some scratches
One damaged plastic toy
I wrote a letter with pictures to the company's president and got a letter back from customer service rep saying they only covered products under warranty. I called her today, and was told it obviously wasn't their problem since it didn't fail within the warranty period, and something to the effect of you can't expect things to last forever. She is going to be sending me new clips but I'm a little scared of the thing at this point, and losing a customer didn't seem to bother them.
If anyone has had problems with these things, you might want to give the company a call, since they apparently have heard only positive feedback.
Oh, and my equipment does all fit within the advertised weight limit per-shelf.
Post edited by John in MA on
«134
  • John in MA
    edited August 2011
    The actual failure spot is the clips that hold the shelves. They're made out of brittle cast metal and most of the ones on my rack are now broken or deformed. It seems that weight over time will cause them to bend and eventually fracture.
    This problem is compounded by the fact the shelves aren't actually held into the clips by any positive means. It's a friction fit with a plastic setscrew. When the clips or screws go out of spec, the shelves are just free-floating with only about a 1/2" of support keeping them from falling.
    In my case, the lower ones broke and the tension of the IC cables pulled all the other shelves out. Most of them got their clips bent, although a few clips just pulled out since the friction fit isn't that secure.
    Here are some pics.
    Before:
    After:
  • dee1949
    dee1949 Posts: 1,425
    edited August 2011
    ....looks like "EARTHquake" damage to me. File a claim.
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited August 2011
    That poor poor Mcintosh
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • greyford1979
    greyford1979 Posts: 749
    edited August 2011
    Amazing none of the glass shelves didn't break:eek:
    I love animals, they're delicious!
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited August 2011
    Probably tempered glass and the rate it fell on each other. At one time I thought about getting a Bello rack. Looks like the equipment took a few licks ,but came through fine. This is the reason I always put the power amp on the bottom shelf(wood ,not glass) and the lighter components on the glass shelves.
  • John in MA
    edited August 2011
    I used to have a bigger power amp on the bottom-most shelf, and the little Rotel above it.
    Tempered glass apparently doesn't count for much when it's Bello:
    http://www.ripoffreport.com/television-parts-services/bell-o-international/bell-o-international-corporati-47dd7.htm
  • Polkie2009
    edited August 2011
    Wow, that picture looked awful, I have to wonder if the glass Bell'O was using on his tv stand was made in China??? Every so often it seems that Chinese made stuff is found to be inferior. Remember that Chinese made sheet rock and wall outlets or something a couple of years ago?
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2011
    release the Kraken on them...come on guys....a Polkie is getting offed here, unfortunately, they sure as hell dont give a crap, so lets give em a buzz by and let Bello know our displeasure.
    i have had a Bello rack for years...it has a different type of support, its spherical and looks more stout than John's pic...so could be they reduced quality of the support..whatever the reason that should not happen.
    RT1
  • Polkie2009
    edited August 2011
    +1, definitely looks like a defect Bell'O dropped the ball on.
  • codyc1ark
    codyc1ark Posts: 2,539
    edited August 2011
    Sent to Bell'O -
    To whom it may concern,
    I was considering Bello racks since I had read positive reviews about build quality. A member of our forum recently had a very bad rack collapse and told of the response from your company, I'm very disappointed. I would think that an A/V rack company would understand the flaw in the product and address it. If you we're a true A/V furniture supplier you would understand that we buy equipment to last a long time, not a few years, electronics or not. I’m going to continue my search, but with customer service like this, I know to look elsewhere.
    Sincerely,
    Cody Clark
    http://www.polkaudio.com/forums/showthread.php?t=123383
    All of this is true, after the addition of a hefty AVR, amp, and soon a new player I'm running out of room and capacity. These looked like solid racks, they may be, the response they have given to him is unacceptable in my opinion from an A/V based company. I will not consider their products in the future with a response like he received.
    The Kracken has been released.
    -Cody
    txcoastal1 Posts: 13,519
    edited August 2011
    I would send them this link with a smile and make sure you post this on other forums that you are a member, and send those links also.
    what a ****
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2011
    Wow, that's messed up John. I'm sorry to read this for sure.
    Let them know that Polk Audio Club Polk has formally removed them from the recommended brands, just in case.
  • Conradicles
    Conradicles Posts: 6,376
    edited August 2011
    No disrespect but that looks like a really weak stand.
  • scottyboy76
    scottyboy76 Posts: 2,905
    edited August 2011
    But where else are you going to get active empathetic support like you do here, not kissin up, just the truth.
    humpty dumpty was pushed
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited August 2011
    Those pictures are tough to look at, just glad nothing was damaged more badly and thank goodness there wasn't a small child playing with the cables when it happened.
  • John in MA
    edited August 2011
    The stand itself feels quite strong. Not as strong as a Salamander or something, but enough to do the job. The combination of the defective clips and poor shelf retention is the real killer. If these guys don't make good on it, I'll probably end up machining a new support mechanism.
    I appreciate all the support, guys. Just don't go too far with the vigilante justice.
  • codyc1ark
    edited August 2011
    John in MA wrote: »
    Polkies can get serious, watch out! :eek:
  • John in MA
    edited August 2011
    codyc1ark wrote: »
    I'm serious. I wish the company was more responsive but I'm not trying to start an uprising here.
    nooshinjohn Posts: 25,998
    edited August 2011
    My thoughts as well. there is no way in hell I would even contemplate putting my remote on that stand, much less my gear, ever again. I don't care if the new clips are made from unobtainium and welded by the hand of God to the frame.
  • Drenis
    Drenis Posts: 2,871
    edited August 2011
    That's sad to look at. I'm surprised how tough my metal/glass stand is. Definitely a poor design.
  • Gadabout
    Gadabout Posts: 1,072
    edited August 2011
    txcoastal1 wrote: »
    what a ****
    It was posted a month ago in Audio Karma.
    Sorry to hear about your equipment. That truly sucks
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • BeefJerky
    BeefJerky Posts: 1,320
    edited August 2011
    Wow, sorry to hear that; the pictures really are quite painful to look at. I'm just glad that the equipment survived. When I look for an equipment rack in the future, it certainly won't be from Bello.
    If they had simply responded in a more helpful and understanding manner, the situation would be very different. However, it is clear that they do not care about their customers after the equipment has been purchased.
    On a side note (not really related, but sort of), Logitech has absolutely fantastic customer support. They've always been very helpful in taking care of defective products, including their keyboards/mice and the Harmony remotes. In fact, I had a problem with my Harmony 900 that I purchased used from this forum; the battery had expanded in the remote, and couldn't be removed. This was not only out of warranty, but I wasn't even the original purchaser. Nonetheless, they didn't hesitate to send me a brand new replacement remote, and they just had me discard the old one. I can't recommend this company enough!
    F1nut Posts: 52,000
    edited August 2011
    That's a sad sight.
    That's what is known as pot metal. It doesn't get any cheaper or weaker and should have never been used in that application.
    I've always thought they valued aesthetics over structural integrity when it's not hard to have both.
  • george daniel
    george daniel Posts: 12,096
    edited August 2011
    bummer to say the least
  • decal
    decal Posts: 3,205
    edited August 2011
    Did you have the feeling that the parts were inferior when you assembled the rack?
  • newbie308
    newbie308 Posts: 811
    edited August 2011
    That is a serious liability! If a young child was using that unit to help them stand up (which they tend to do) , a failure of that magnitude could have seriously injured, or even killed, a toddler! How much profit is a child's life worth?
    Bad Business! Cheap pot metal crap probably manufactured in China! If my business was on the line, I'd be recalling the entire product line. Yeah, the cost of such an act may bankrupt my business, but at least I could sleep at night knowing that I was not responsible for the potential death of a child!
  • John in MA
    edited August 2011
    I originally thought they couldn't have been that dumb and that it was something like MIM steel (injection molded,) but you're right. Non-magnetic and gray--it's a zinc alloy.
    decal wrote: »
    I got it fully assembled, but I never liked the look of the shelf support method. My assumption was "well they sold this thing for years, so it must work."
    newbie308 wrote: »
    That was my first thought. I'm not dumb enough to have kids, but if someone's toddler wandered into the room and leaned on the amp, I'd be cleaning up more than stereo parts on the floor.
    edited August 2011
    That's just nasty and inappropriate at that 'price point'. Really, a few letters to the manufacturer are in order here.
    I can't believe how delicate those clips are for a $650 dollar rack. Way out of my range. I have a $25 dollar glass unit (bought on closeout--regular price $100) that really doesn't look that different from what you have there. As said above, I keep the 51lb. Onkyo on the lowest shelf. Everything else is bearing less than 20 lbs. per shelf.
    You actually seem pretty level-headed considering what happened. I'd be beside myself and ready to storm Bell'O Headquarters. lol
    Hope you come to some resolution of this. It does look, though, as if most of the gear suffered mostly 'cosmetic' damage--which 'sucks' but at least it still works. That still doesn't 'excuse' what happened.
    cnh
  • grimmace19
    grimmace19 Posts: 1,429
    edited August 2011
    Great, now you have me looking at my bell'o tv stand and waiting for my 65 inch plasma to come crashing through all my gear on the inner shelves...
  • codyc1ark
    edited August 2011
    cnh wrote: »
    +1 to that, but I guess in this type of situation a level head is best. If you go to there website you can hit contact and it'll link you to where you can leave a comment, I did as showen above. I just don't understand the response he got. At the VERY least they could have offered to replace his shelf holders so he could continue to use the rack, if not the whole rack because the shortcut they took led to his damaged equipment.
