Need some info on some SDA's
    heiney9 Posts: 25,432
    edited August 2011
    Joe08867 wrote: »
    All the brilliance was back without the sibilance or nastiness that the 194 had added.
    Sorry Joe, but I have to disagree the 194 has NEVER in my experience had sibilance or nastiness. It's one smooth and extended tweeter. Something else must have been wrong.
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited August 2011
    Polk redesigned the crossovers in all of the Later SDA's to work with the Tri-Laminate tweeters as I believe they are a different Ohm Rating and have very different parameters to deal with in the crossover. As a result the 194 will sound completely wrong in a circuit designed for the 198.
    I understand this completely. However what is really being said (I assume) is not that the 198's can't be used in almost anything, but that it would take major cross updates and changes to make it work properly and experience what they are capable of delivering. I get it though, as sometimes in car audio, though pretty much anything could be done, it didn't always make sense to do so.
    If that is the case, I am surprised one of the crossover gurus around here hasn't been successful at putting these in something else.
    This leads me to another thought; are replacement diaphragm/ coils available for any of these tweeters and if so how different are the magnet structures.
    F1nut Posts: 51,757
    edited August 2011
    heiney9 wrote: »
    Brock, something was wrong. By mistake, Joe was using the 194 in a circuit designed for the 198.
    edited August 2011
    Ah, ok.....so it was the 194 in the circuit designed for the 198. Not the 194 in a proper circuit.
    Got it
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2011
    heiney9 wrote: »
    heiney9 wrote: »
    Got it
    That was exactly the problem F1. Normally the 194's are awesome just not in the TL circuit. :eek:
    H9, I agree the 194 is quite smooth and extended when used properly. :wink:
  • nspindel
    nspindel Posts: 5,343
    edited August 2011
    When I spoke to Polk customer service several years ago about it, they told me that the 194 and the 198 are the exact same tweeter, except that the windings are different which accounts for the different electrical characteristics. In my experience, the difference between SL2000 and RDO-194 is enormous. The difference between the 194 and 198 is there, but it's not earthshattering the way going from plastic dome to silk dome is. The 198 is better, but it's not a night and day difference at all. The 194 is a fine tweeter, and my 1C's sound just dandy with them.
    edited August 2011
    nspindel wrote: »
    Exactly +1.
    The sl2000 and sl3000 were worlds apart and a completely different design from each other. The sl3000 being the better tweeter.
    The RD0194-1 and RD0198-1 are extremely similar build and material wise, cut from the same cloth so to speak, with slight electrical differences based on the circuit they fit into.
    Not a huge difference in overall sound and presentation, they are very close and both are great sounding tweeters.
  • Mr. Bubbles
    edited August 2011
    Can I safely assume the 194 is a 4 ohm version and the 198 is the 8 ohm version.
    edited August 2011
    Not quite as cut and dried as that. You keep asking about x-over guru's tweaking a speaker to use the 198 instead of the 194. It's all here if you can find it.
    the 4.1TL is the only factory approved modification which allows for the use of the 198 in place of a 194 but only certain model SDA's can be done this way. Matthew Polk and other Polk engineers ahve been queried about this and have actually given their .02c.
    Again, this has been covered exhaustively on Club Polk in the past, if you can find it. Our search engine is not very good.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited August 2011
    heiney9 wrote: »
    Google your question with "club polk" included. Far better than the CP search engine will ever be.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited August 2011
    nspindel wrote: »
    That is a great way to put it. I think most listeners will find the the 194 is perfectly matched to the 1C, and the 198 should be used anywhere else that it can be properly integrated.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Mr. Bubbles
    edited August 2011
    I was primarily trying to understand why i keep reading that the 198 can't be used in this model or that model but can be used in a different model. please understand that I realize somethings are more complicated than others but most are still possible. i'm just trying to understand. I am a relatively new fan of the vintage polks. When i was in car stereo, Polk was nothing special, either for SPL or sound quality. That was several years ago and things may have changed by now. For my home sytems, I have primarily owned and listened to DCM, klipsch, and Cizek's in the past, for my home listening. i was actually purchasing a pair of DCM TF1000's from a guy who had recently acquired a pair of SDA1.2TL's. Listening to them didn't deter my purchase but definitely gave me the bug. I now have the 2B's and 1C's and am trying to learn as much as i can about these. The SDA's are definitely my fav's on my 2 ch systems. i tried them on my theater and they bombed in my opinion but with the functional theory they involve that does not surprise me and i wouldn't expect a perfect surround sound using SDA technology, though I notice a good many members here seem to use them for that.
    I know a lot of this may not match this thread, but as i said i am just trying to learn as much as possible about the vintage polks and especially the SDA's.
    edited August 2011
    It's real simple, Polk used approximately 7 different tweeters (or more) in the classic models the RD0194 and RD0198 are designed to be used as modern replacements since none of the 7 tweeters are still being produced.
    The 194 has certain electrical characteristics that match up with certain models of the (7) original tweeters.
    The 198 has certain electrical characteristics that match up with certain models of the (7) original tweeters.
    Also some SDA's used a progressive point source in the tweeter array, some didn't. Some used a tweeter in the SDA circuit some didn't.
    What is so hard about that? It's not rocket science, certain parts on the same model car only fit certain years, same goes here for same model speakers made in different years with slightly different parameters.
    P.s. Certain later model SDA's can be modified to use the 198 instead of the 194, this modification is a factory modification that never made it into production because the SDA line had stopped being manufactured before it could be implemented.
  • Joe08867
    edited August 2011
    Here is a link to work Darqueknight did with the 4.1TL mod on some SDA CRS+'s.
    This takes the 194 out and puts the 198 in. It is a good read.
    4.1TL modification for SDA CRS+
    edited August 2011
    The 4.1TL mod being the name Polk gave this modification internally. Again, SDA's ceased production before this factory mod could be implemented.
  • Mr. Bubbles
    edited August 2011
    All this is already understood and you are right; nothing complicated about it. however, it still does not answer my question. Why do members around here refer to the 198's as not able to be used in certain models. I am from the world that almost anything can be made to work if you want it bad enough and are willing to put in the effort. i was originally under the impression (from reading here in the forums) that the 198 was much better than any other tweeter Polk ever produced. in fact that is very cl9se to the reply that 1 member gave here recently. I was simply curious that if they were that much better than anything else why it was accepted as not working in other models. Now I find that it is essentially the same as the 194, only slightly different for use in very similar but different circuits. So, since it is not the end all be all that i was impressed it to be, there is no reason to put forth the extreme effort that may be required to make it work in other models. Again not that complicated. i was just confused from reading the opinions of some members replies.
    edited August 2011
    Why do members around here refer to the 198's as not able to be used in certain models. I am from the world that almost anything can be made to work if you want it bad enough and are willing to put in the effort..
    As I said before, the answer to that question in detail is here amongst the archives, get you reading hat on.
    i was originally under the impression (from reading here in the forums) that the 198 was much better than any other tweeter Polk ever produced. .
    The 194 and 198 are essentially the same tweeter except for some electrical differences. IMO, members overstate how much better the 198 is vs. the 194
    All sorts of opinions, etc. There was one person on here that praised the 198 over the 194 after futhur questions he admitted the 198's were used in a circuit with new premium parts (caps and resistors) and the 194 was used in a circuit with original aged parts. Also they were used in different speakers. So his opinion to me is invalid by a wide margin.
    F1nut Posts: 51,757
    edited August 2011
    Because the high frequency circuit would need to be completely redesigned.
    By all means, knock yourself out.
    For the SDA's that can use that tweeter, it is better than anything else.
    See my first comment.
    They may be close in build, but the end result favors the 198/TL crossover over the 194 by a good margin, IMO.
    Read my comments here, http://www.polkaudio.com/forums/showthread.php?t=46489
  • FTGV
    FTGV Posts: 3,650
    edited August 2011
    I have no experience with either the 194 or 198 but if I were a betting man ,would guess the differences between them relates to impedance and sensitivity.If thats indeed the case they would not be interchangable as it would require a reworking of the crossover.
  • y_w8
    y_w8 Posts: 13
    edited August 2011
    I'm looking into updating my original SDA's. I can find the Solen Caps and Mills Resistors, but, where can I purchase the 194's?
  • xsmi
    xsmi Posts: 1,801
    edited August 2011
    Polk customer service.
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • gdb
    gdb Posts: 6,012
    edited August 2011
    y_w8 wrote: »
    Call the toll free number at the top right on this page, tell em Drenis sent you, for a generous discount!:wink:
  • y_w8
    y_w8 Posts: 13
    edited August 2011
    F1nut Posts: 51,757
    edited August 2011
    You do not want to use them in the high freqency circuit.
