APC review or panamax
myke
myke Posts: 138
edited August 2011 in Electronics
Since my original thread went haywire with talks of 5k+ power conditioners that have no real bearing on the topic I posed, I have started this one for "simple"people who can't/won't spend that type of money.
Just want your thoughts on the listed conditioners for the system below:
APC G50B-20A2 Line Conditioner
Panamax M5100-PM
Panamax Max 4300-PM
Tripp Lite Isobar HT7300PC Power Conditioner
Thank you,
Bonus Room:
Pioneer Elite VSX-32
RTi A7's / CSi A6
DSW PRO 600 sub
Emotiva XPA-5 & Interconnects
Sony Surrounds (rears) - replacing soon
Samsung BD-C5500
Panamax M5300, Xbox360, ...& more coming
Living Room:
Samsung 58" PLasma
Monoprice in-ceiling speakers
old sony receiver (replacing soon)
Post edited by myke on
«13
    heiney9 Posts: 25,431
    edited August 2011
    My APC has been excellent, no complaints and it does what it says.
    Panamax has a long and excellent reputation as well so with either one as long as you are comparing apples to apples either one is a great choice.
    EndersShadow Posts: 17,704
    edited August 2011
    So the Panamax 5300 has 10 outlets and the other two both have 8.
    If it were me I would go with the 5300. Both brands are good as are all three products, however the 5300 has the most outlets which allows for better connectivity and flexibility when adding in new components.
    It also depends on how many components you have. I personally have 9 pieces of gear (AVR, Amp, Sub, DVR, Router, TT, Bluray player, Xbox360, Laserdisc player) + 1 TV so I personally need 10 outlets min unless I pull some gear out of my system (which I dont plan to do).
    If this is for a 2 channel rig, go with the cheaper of the 2 8 outlet models since you shouldnt have that many components.
    Also something to think about is making sure if your connecting power to also connect LAN data lines, otherwise your still technically unprotected. In my case I use Uverse and they have a data jack that sends my TV to the router. I need 1 LAN in (to connect the incoming line to the protector) and 1 LAN out (to run that now protected LAN line to the router).
  • myke
    myke Posts: 138
    edited August 2011
    I really starting to lean towards the Tripp Lite, plenty of features too, plug - ins, trigger, etc.. and i can get it cheaper than I can for the Panamax 5100(which $ plays a small role), any thoughts on the Tripp Lite?
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
    edited August 2011
    If one of them has voltage regulation, I'd choose that one regardless of the number of outlets. Voltage regulation is a nice feature to have especially during times of brown-outs, etc.
    edited August 2011
    What are looking for it to do?
    Some are line conditioners, some have voltage regulation, some are just surge supressors. Some are all 3 and more.
    edited August 2011
    edited August 2011
    Those are glorified power strips for surge supression.
    the "H" series are power conditioners some have voltage regulation
    the "S" series are power conditioners w/battery back up
    That's why I asked what is he looking for?
    P.s. Nothing wrong with the "C" series you linked to if that's what th OP is looking for, but they aren't line conditioners.
  • dkg999
    dkg999 Posts: 5,647
    edited August 2011
    I have a Tripp Lite LCR-2400 for my HT and a Panamax 5100 for my 2 ch system. I would rate both at very good performance for removing noise from the AC feed and not limiting amplifier current draw. If I had to buy a new power conditioner it would probably be a Panamax.
    DKG999
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited August 2011
    H9 brings valid points for you to consider so...
    The amounts of outlets is important in the way it has to accomodate your system and potential upgrades however, it is often a common mistake for one to focus so much on the amount of outlets versus price point and neglecting the specs (what the product can actually offer),
    First you need to determine what is your local power condition (frequent variations, un-steady, noize, frequent surges, power failure and so on) as from this you can determine what you need and pay for exactly what you need no more no less.
    What type of electronic system you are powering as it will again determine the options that are required for your specific needs. So compare apples for apples and then pick best bang for the buck within the products that best suit your specific needs.
    Surge suppression is definitley a must to protect your investment.
    With audio gear (also video), filtering is also important especially if your power line is noizy and surrounding appliances and other electronic gear are prone to generate noize. The db rating is very important in this instance (the higher the better).
    Any requirement for battery bac-up in your area?
    I find the below article to be quite educational to understand what conditioners can do for you; http://www.wisegeek.com/what-is-a-power-conditioner.htm
    While bias (promoting own products) I find this site very interesting and informative; http://www.zerosurge.com/sitemap.cfm
    You have to know exactly what you need or want to achive and be aware of the specs offered by each product. It's OK to look for the best bang for the buck but at the same time you have to realize you get what you pay for and sometime going down in price may mena loosing a feature that you may need.
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • dkg999
    dkg999 Posts: 5,647
    edited August 2011
    ^^^^ or you can just buy one that matches your gear, looks nice on your rack, has pretty blue lights and nice meters, etc.
    DKG999
  • myke
    myke Posts: 138
    edited August 2011
    as far as what i'm looking for is Surge suppression, filter line noise, filter surrounding appliances and pops when fleuresents turn on. Not to mention to condition the lines for amps, avr, & other gear as well as protect them. Living in NC I think I have decent power (no brown-outs etc....) aside from the occasional loss or surge. Dont know much about frequency coming in etc.. Also don't know what I don't know if that makes sense.
    Trying to match(compliment) a power manager/conditioner/surge protector with the system i have.
    Also 8 plugs could work ok but it would be better w/10 or more
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
    edited August 2011
    Since I have current direct experience with APC the H10 or H15 would do everything you need.
    I'm sure Panamax has an equivalent that would work as well.
    All three brands you mention have great products. If you increase your budget and want something a tad more audiophile rated you could look at PS Audio.
    edited August 2011
    heiney9 wrote: »
    And just looking at pricing for something from Panamax, the APC products are priced lower.
    You can get the H10 from Vanns.com for 200, whereas the Panamax you would need if you wanted 10 outlets is ~350+.
    As to what the difference between the H10 and H15 is I couldnt tell you...
    edited August 2011
    The H15 has a nicer more comprehensive display, more outlets, more capacity if the OP goes to APC's site you can do a spec comparison there.
  • digitalvideo
    digitalvideo Posts: 983
    edited August 2011
    Why mov based plug-in surge protectors should be avoided...
    How to Choose a Surge Protector:
    http://www.djsociety.org/Surge_1.htm
  • DMara
    DMara Posts: 1,434
    edited August 2011
    Here we go again, the SurgeX troll :biggrin:
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
    edited August 2011
    Not you again, like a stain you can't "Shout it Out"
  • TECHNOKID
    edited August 2011
    Please let's stick to the OP needs this time (he took the time to star a second thread since his original one moved away from his needs and was turning into a best product contest). I believe we all aware of MOVs pros and cons and it is NOT the subject at hand!
    BTW; the OP is not looking for an SP (stay away from that world! somebody is googling that word and pops up every time it comes up here at CP) but a line conditioner (the SP is normally included in good ones)
    DARE TO SOAR:
  • myke
    myke Posts: 138
    edited August 2011
    yeah but the apc only has 8 outlets vs. tripp lite has 12 & here's another area i'm curious about:
    APC - Surge energy rating - 3400 Joules
    Tripp Lite - 5700-joule surge suppression rating
    APC - APC AV 20 Amp G Type Rack Power Filter
    Tripp-Lite - Output volt amp capacity (amps) =12
    so which one matters more (or less)?
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited August 2011
    I say panamax as they are cheap , look great and get the job done
    avoid the big box stores when buying and look around on amazon for great deals on conditioners
  • TECHNOKID
    edited August 2011
    myke wrote: »
    So far the trip lite seem to be your best bet however, more details would be ideal for you to make a sound decision. As I pointed out, don't focus on the number of outlets in such a way that it leads you away from the actual specs.
    DARE TO SOAR:
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2011
    heiney9 wrote: »
    I have 3 Panamaxs and never had any problem with them, although I will be upgrading my two-channel Panamax to a $5k device in the future. :wink:
    Anyway, one night in the HT I was playing music, and was watching the voltage meter on the Panamax, and it would be steady, and then drop into the 90s, and go back up into the low 100s. I thought PG&E was having power problems, but it was a breaker going bad. As soon as the power dropped below 90 then BAM. The Panamax shut everything down so fast that the sudden quiet was like an explosion. They said it monitored the voltage, and it does.
  • TECHNOKID
    edited August 2011
    myke wrote: »
    I like this, does your trip lite offer the same feature? Don't forget to compare db rating also as this is the spec that will affect noise going through your audio.
    DARE TO SOAR:
  • myke
    myke Posts: 138
    edited August 2011
    I can actually get the tripp lite ht7300pc or apc av20 cheaper than the panamax and i think both look better than the panamax M4300-PM.
    I found this on the web-site, "Fail-safe thermal fusing acts like an additional circuit breaker, shutting down the unit and connected equipment in the event of a catastrophic surge"
    http://www.tripplite.com/en/products/model.cfm?txtModelID=3346
    Here's the site if someone wants to see it, I guess i assumed all of them have a safety which trips a shutoff for too little or too much incoming voltage.
    And the tripp has a higher joule surge rating but the apc has a higher amp rating.....which matters more??
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • Marty913
    Marty913 Posts: 760
    edited August 2011
    myke wrote: »
    The APC H10 has 10 outlets and the H15 has 12 outlets & 5270 Joules of protection. Both have voltage regulation, noise filtering, protection, etc. If you're looking at the Tripplite 7300 for 3-bills you should probably be comparing it to the APC H10 or H15.
    Not recommending one brand over another, just that "apples to apples" thing.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • myke
    myke Posts: 138
    edited August 2011
    I was looking at the APC G50B-20A2 , which is prob why i'm getting a better deal. Makes sense why I thought the Tripp was better, suppose the two models are more like apples to oranges.
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • myke
    myke Posts: 138
    edited August 2011
    Stupid question:
    Regarding the APC 10H, when it says:
    "Rated Watt Capacity (continuous): 1000 Watts"
    does that mean the 5x200w amp i'm going to be plugging into it along with my 58" plasma and other gear will I need more capacity? Should I go to the APC 15H for more capacity?
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
    edited August 2011
    myke wrote: »
    Stupid question:
    ONLY if your amp is maxed out on power, which is an unlikely event. However the H15 isnt a bad call either.
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited August 2011
    myke wrote: »
    Stupid question:
    depends on your total watt draw. But if you have the tunes cranked with other items running at the same time it could result in a overload.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • westom
    westom Posts: 45
    edited August 2011
    myke wrote: »
    How often do incandescent bulbs dim to less than 50% intensity. If not, then voltages are virtually unchanged as far as electronics are concerned.
    Line frequency is another strawman. A mythical problem created subjectively in advertising to promote their product as a solution.
    Noise from AC mains must be eliminated by numerous and superior filters inside electronics. Noise entering via other paths (ie safety ground, signal ground loops) requires other considerations. No magic box is permitted to block or filter noise on a safety ground wire.
    Surge suppression is not found in the specs of any of those requested products (APC, Panamax, Tripplite). If it does protection, then its numeric specs define protection from each type of surge in numbers. If no protection numbers exist, then it does ineffective protection. Anyone making subjective claims is essentially lying. It does protection only if numbers define that protection.
    Numbers such as 3000 or 5000 joules will somehow absorb surges that are hundreds of thousands of joules? Hardly. Those power conditioners claim to absorb tiny surges that do not harm appliances. Do not claim to protect from surges that actually do damage. Such surges, that can overwhelm protection already inside appliances, occur maybe once every seven years.
    If a supply inside your electronics is defective (does not filter noise), then a serious series mode filter maybe needed. Those are heavy. That kind of filtering comes from companies such as Zerosurge, Surgex, and Brickwall. Better is to solve the problem where it was supposed to be solved - inside electronics.
    And finally, this quote is not from specs and is an obvious electrical lie: "Fail-safe thermal fusing acts like an additional circuit breaker, shutting down the unit and connected equipment in the event of a catastrophic surge"
    Fail-safe thermal fuses are necessary because the protector is grossly undersized. Thermal fuses disconnect protector circuits as fast as possible when a destructive surge (hundreds of thousands of joules) is being absorbed by its near zero joules (3000 or 5000). If thermal fuses do not disconnect protector parts fast enough, then a house fire may result. Meanwhile, those thermal fuses also leave that surge connected to adjacent electronics.
    Protectors that are properly designed to do protection will even earth direct lightning strikes - and remain functional
    You must decide what you want to cure. Noise and surges cannot be solved at the same location. Your power conditioner claims near zero protection from surges that are not typically destructive. But that is only obvious by always reading spec numbers. Honest answers cannot and do not exist in any reply that is subjective. Only numbers for the APC, Panamax, and Tripplite define what it really does.
