Front effect speakers
Anyone running front effect speakers with a Yamaha rxv1400?
Worth the extra money for some more speakers?
Post edited by Donduck on
I wouldn't buy until I knew how much I would use them. Borrow a pair from a friend, they don't have to be topshelf speaks to see if you like the effect. Yamaha uses the effects on their own dsp soundfields. I think the front effects are used up in the front corners of your room to widen the soundstage.
Those speakers aren't used for Dolby Digital, or DTS decoded tracks since those tracks were never recorded into the original material. I may speak out of turn, since I don't own Yamaha, but many say that the effects are cool when you first get them for listening to music, but the novelty wears off and you find that the normal speaker placements with the decodings intended for movies are the best overall settings. That feeling is not exclusive to Yamaha, most people just don't use the receivers to produce sounds (dsp fields) from there receivers that weren't part of the original recordings.
Try it out and let us know how you like it,
DennisHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Thanks for the info. I'm still waiting on the rxv1400 receiver till Wed. or Thurs. Might hook up my little jvc satellites left over from my other setup to check the effect out. Around here they are still selling the Polk R15's for $38 each. I could save $80 by not buying these.
Front - RTi4's
Center - CSi3
Side Surrs.- R15's
Rear Surrs. - R15's
Sub - Psw303 -
Front Effects, depending on what they are used for.
Yamaha's older units just used the front effects for phantom modes (opera house, stadium, etc etc) - they are NOT used for movies.
Again, depending on how this design puts them to use, the older DSP models used them like I said above.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
sunfire added front efects to their tgIII if i want to use them i need a nother 2 channel to drive them. but i think you can use them with movies. also they have a tgIV out allready the olny diferance is wideo up conversin.
i have the rxv-1400 and unless you are going to have 9 speakers plugged in then i wouldn't use the effects speakers.
they are only used in yamaha's dsp fields which so far i haven't liked. If you want dolby ex and thx ex which is awesome you need the back surrounds. the reason i don't like the dsp is the music was processed and effects put on in the studio, so the dsp is overkill. For instance, i love acappella music, but these guys usually record IN the hall so if you listen in hall mode it's just to much echo. If they recorded dry, then the effects would sound much more lifelike.Front RTI4s
Center CSI3
Velodyne ULD-18 Sub
Pioneer DV-563A Dvd, SACD, DVD audio player
Sony CDP-CX355 300 disc CD player
Technics SL-7 turntable
Yamaha RX-V1400 A/V Reciever
Dish Network DVR
Playstation 2 and 3 both optical out
Sony Wega 34" Widescreen CRT HDTV -
I don't think the Yamaha 1400 or 2400 will let you do surround backs and front effects at the same time anyway.
