RTi A7 and amp
hi guys,
i'm new to the forum and to polk speakers...i just bought a pair of RTi A7's and would like to know the amount of power that i need to match with it. after doing some research, i've come across a few different answers so i figured i'd ask you guys for a more definitive answer.
Now, i know the speakers are rated at most 300 w/channel. So, do i get an amp with 600 w/channel RMS, OR an amp with just a little more than that, for ex, 450 w/channel RMS, OR just an amp rated at 300 w/channel RMS??
Any advice is much appreciated...
Post edited by rolla on
welcome to the club,
i beleive that most people here will agree that you can push the rtia7 well with any amp with 125 to 200 of good clean real power, so 125 to 200 watts/channel rms is plenty and enough.
i push mine with a rotel rb990bx that puts out 200 watts per channel rms and have gotten great results and have never used it past 60% and trust me that is plenty loud and clear.
good luck
p.s: if you are going to use an avr get the sc series from pioneer eliteHT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES -
I run mine off of my Denon AVR 2808 and they sound great.
I have hooked my Parasound up to it and it was nice, but not a huge gain... Lowend hit harder and tighter, but overall the Denon does a good job with them (2ch music).
If I was able to run a lot of demanding HT stuff still (8 month old baby is a movie buzz kill), I would be getting another Parasound to take the strain off the Denon in 5ch mode. But I have to keep it sooo tame right now that it would be a huge waste. -
thanks for the advice...however, if i did want to go one of those routes, which would be the best to get??
... if i did want to go one of those routes, which would be the best to get??
What routes are you talking about here? Getting a 2 channel power amp?
Many options.
A price range and other associated equipment would help.
BTW, welcome to Cub Polk!!!:biggrin:
Tons of great info here!2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
thanks for the welcome!
i was looking at 2 channel amps:
Crown - 440W at 8 ohms:
http://www.amazon.com/Crown-XLS2500-Amplifier-integrated-Crossover/dp/B003HZV2OI/ref=wl_it_dp_o?ie=UTF8&coliid=I3QNHDPQURORUV&colid=1SYFWJIXK3PWU
Crown - 375W at 8 ohms:
http://www.amazon.com/Crown-XLS2000-Amplifier-integrated-Crossover/dp/B003HZPKXC/ref=wl_it_dp_o?ie=UTF8&coliid=I1HNXT6RA2R7K4&colid=1SYFWJIXK3PWU
Crown - 300W at 8 ohms:
http://www.amazon.com/Crown-XLS1500-Amplifier-integrated-Crossover/dp/B003HZV2JS/ref=wl_it_dp_o?ie=UTF8&coliid=IBQWO37591EPJ&colid=1SYFWJIXK3PWU
QSC GX5 - 500W at 8 ohms:
http://www.amazon.com/QSC-GX5-Stereo-Power-Amplifier/dp/B0018D84YC/ref=wl_it_dp_o?ie=UTF8&coliid=I17S3XZODDINMJ&colid=1SYFWJIXK3PWU
QSC GX3 - 300W at 8 ohms:
So, my question is do i just get a 300W amp to match the speakers or do i go higher??
Also, would you go for a Crown amp or QSC? -
Don't worry about more or fewer watts; worry about better or poorer amp design.
A smaller quantity of good, clean, high current watts is better than a large quantity of bad watts.
*Take a deep breath and leave your bias towards high numbers behind*
Your price range appears to be 400-700, correct? There are a ton of great power amps out there, on the used market, worth considering.
Brands to look into (I'm forgetting a ton):
parasound, rotel, b&k, adcom, bryston, nad, etc...
I agree with EDUBAG, 125-200 watts per channel into 8 ohms of good power is plenty.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
wow, thanks for the heads up on the other brands! looks like its back to the drawing board for me!
and yeah, 400-700 is my price range...
would you have any suggestions as to which brand to start looking at first?? -
Leave the pro audio gear out of the mix for best results... Welcome to the club.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Here is a random assortment off of Audiogon to get you started...
Rotel RB 1080 200wpc amp - $500
Parasound HCA-2200 (I) 200wpc amp - $560
NAD c272 150wpc (220w dynamic) - $399
Adcom GFA 555II 200wpc - $395Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
Providing us with the other associated gear you'll be using and ideas about what you're trying to achieve will help a lot.
It may be that you're better off spending less on the amp so you can spend more addressing deficiencies in your system that we can't tell you about unless you tell us, so spill it...
Welcome to the club, Rolla. Ditto to: A smaller quantity of good, clean, high current watts is better than a large quantity of bad watts. Consider my Belles rated at a mere 80* watts into 8ohms will lift my 'A7s off the ground!falconcry72 wrote: »Don't worry about more or fewer watts; worry about better or poorer amp design.
Brands to look into (I'm forgetting a ton): parasound, rotel, b&k, adcom, bryston, nad, etc...
* high current and warm sounding
Me too!falconcry72 wrote: »I agree with EDUBAG, 125-200 watts per channel into 8 ohms of good power is plenty.
cheers tonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
All great amps*. Consider a Hafler XL280 - $225**. From the manual:NONE OF THOSE (Crown, QSC) GET THESE:
Rotel* RB 1080 200wpc amp - $500
@ 8 ohms: 145wpc/180w clipping
@ 4 ohms: 200wpc/280w clipping
@ 2 ohms: 290wpc/360w clipping
@ 8 ohms mono: 400w/560w clipping
I list the lower impedance power ratings because, below 125hz, the 'A7's impedance slides to 4 ohms.
* if I knew then what I know now I would have bought Rotels instead of Hafs; plan to upgrade after I finish other details
** shipped from ebaySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
wow, i feel like such a beginner...lol
thanks to all for the great replies...much appreciated
well, in reference to my current setup, i dont have a home theatre set up in my place as i am not really into such things...i'm just looking for a nice basic audio setup to play music...right now, i have an Onkyo preamp, Yamaha 10-band EQ, wired to a powered 15" subwoofer and to the RTi A7's, which are hooked up to an Onkyo M-504 amp (165W/channel, 8 ohms)...
so, from what's been posted, i guess i'm better off staying with the current amp, assuming that the Onkyo amp is providing the necessary clean power??
