My first attempt at building a Server
Serendipity
Serendipity Posts: 6,975
edited August 2011 in The Clubhouse
So today I decided to build a small, basic server with the goal of managing my data, print jobs, network logons, and AntiVirus (I have Symantec Antivirus Enterprise edition, which can be managed over the network):
Motherboard: MSI G41 mATX
Processor: Intel Celeron Dual Core 2.4GHz
Optical: Toshiba DVD-ROM 16x
Memory: 2.0GB DDR3 non-ECC
Video: Onboard Intel Graphics X4500
Power Supply: Allied 300W mATX
LAN: Onboard Realtek Ethernet
FireWire: Pyro Digital Video 1394 Card
OS: Legal version of Windows Server 2008
RAID card
Everything was going smoothly until I plugged in the RAID card and attached the two PATA drives. I have a third, but I haven't installed it yet. What happens is the machine displays the RAID card startup screen, then never goes to the BIOS of the MSI motherboard. I can't press F1, F2, or DEL - or anything for that matter!
Anyone have any ideas what's up? Pics attached of the build.
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • wayne3burk
    wayne3burk Posts: 939
    edited August 2011
    back in the day..... I built to computers based on MSI motherboards for AMD processors.
    One for me and one for my daughter....
    they lasted about 2 yrs before they eventually crapped out.
    I think maybe MSI is crap
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
  • Serendipity
    edited August 2011
    wayne3burk wrote: »
    Could be, not sure why I can't get anything on the screen except a blinking cursor after the RAID card shows its POST display. I don't even see the MSI logo anymore, where I can press a key to get into the BIOS settings. I had spent the entire morning buliding the system and at one point had been able to get into the BIOS, but not anymore. :confused:
  • Serendipity
    edited August 2011
    Ok, so after hours of frustration and not getting anywhere, I swapped the RAID card and the 1394 (FireWire) card and the system started up! Apparently the RAID card didn't like being on PCI # 2 and wanted priority for some strange reason.
    Now I need to install an OS, but there are no drivers for the RAID card (Windows doesn't see the HDDs, but the BIOS sees the 3 drives).
    Is there any way to get drivers into the system before the OS install phase?
    Thanks!
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2011
    That picture reminds of a Computer HTPC style one 160g boot sada, 4 1.5tb sata drives in a Raid 5 setup. The Raid in a HTPC didn't work as well because it cause video to jump and bit up some at times. But all in all looked wild with 5 drives. :smile:
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Serendipity
    edited August 2011
    I just got this working. This setup is AWESOME!
    Basically, the RAID card needed to have its firmware updated before the computer could see the card. However, the only way to update the firmware was via a flash tool using the DOS prompt!:eek:
    Not knowing any DOS commands, I read up on changing the directory using the cd... commands to go to the directory of the firmware update .exe file, ran that firmware update, and voila - Windows installer recognized the card!
    So my lack of knowledge with MS-DOS and running a command prompt firmware update tool was what got me into this roadblock... for now.
    Now that Windows has installed (and it installed BLAZINGLY fast), I have FOUR hard drives available to use!
    EndersShadow Posts: 17,688
    edited August 2011
    hardforum.com is a great resource for computer related questions and problems in case you have problems again. They have a dedicated server section :smile:
  • Serendipity
    edited August 2011
    Thanks, most of the issues I had were not knowing what to do and when.
    Now that I have the RAID software installed, and the card has the latest firmware update, everything seems to be running smoothly!!!
  • nadams
    nadams Posts: 5,877
    edited August 2011
    Do you actually have the drives configured in a RAID array, or do you just have them all plugged into the card. The reason I ask is because you say you "have four hard drives available to use". If the drives are properly configured in RAID, you should only see one drive letter (maybe two, if you have a standalone OS drive). If they're not actually RAIDed, you're not seeing any performance or redundancy advantages.
    Ludicrous gibs!
  • Serendipity
    edited August 2011
    I see four drive letters, can you explain where I went wrong?
    I was able to format each of the individual drives separately.
  • nadams
    nadams Posts: 5,877
    edited August 2011
    Just looked at the pictures again. You've got 3 drives. One SATA (which I'm assuming is your primary OS drive), and two PATA. The two PATA drives you have are on the same chain, which, IIRC would not be able to be configured in RAID. In order to do PATA RAID, the drives have to be the only device on the cable.
    So, it looks like you're just running a bunch of disks (and dissimilar ones at that), so you could've negated all the trouble with the RAID card by just using onboard IDE.
    Ludicrous gibs!
  • Serendipity
    edited August 2011
    Ok, I'll admit this is the first time I am doing this so I have no idea what is wrong.
    I added a fourth drive, with the second ribbon cable plugged into the card. This is an identical drive to the top drive, as I purchased both of them together.
    With the RAID software installed (its running in the clock / taskbar), I see the 3 PATA drives.
  • nadams
    nadams Posts: 5,877
    edited August 2011
    Yes, you would see all the drives individually. But this is not having them set up in RAID.
    Wikipedia can explain the different types of RAID better than I - http://en.wikipedia.org/wiki/RAID
    What's the model number of the card you have? It's possible that it's not even a RAID controller, but rather just a plain jane hard drive controller.
    Ludicrous gibs!
  • Serendipity
    edited August 2011
    It's a Silicon Image SiI0680A.
    There is a jumper on the card that says "RAID enable" or something like that. I have to remove the card to look at it again. The jumper should be in the right configuration.
    I wanted to use the drives as redundancy so if one fails, the other will still have my data.
  • nadams
    nadams Posts: 5,877
    edited August 2011
    For redundancy, you want to use a RAID1 configuration in this case. The two drives are different. Are they the same size? They should really be the same model of drive for use in RAID.
    Ludicrous gibs!
  • Serendipity
    edited August 2011
    Yes, I put in a fourth drive which is not shown in the pix which is the same as the top PATA drive.
    At this point I am seriously thinking about going with a prebuilt Dell PowerEdge server as this was more trouble than I thought it would be...
  • nadams
    nadams Posts: 5,877
    edited August 2011
    Well, if you want to use RAID 1, you should use the two identical drives. Set them both as master, and put them on the two separate channels of the RAID card. Enter the BIOS of the RAID card (not the PC BIOS). There should be an option to create a new RAID set, and then a new Mirrored set. Use auto configuration settings, and it will ask you your primary and secondary drives (which should be 0 and 1), and then it creates the array. Then you need to boot into Windows and format the new drive set to be able to use it.
    It will show up as a single drive letter, and the capacity will be that of a single drive in the set. (You'll still have your standalone SATA drive as "C:") The RAID controller handles the data duplication on the back end, but obviously only the data that you put in the RAID drive letter will be duplicated. If you want EVERYTHING duplicated (IE- OS, applications, etc), then you need to install Windows to the RAID set, not to the single SATA drive.
    Use this as a learning experience to figure out how RAID works. Do some reading... crack open the manual that came with the card (or go download it off SIL's website), and get your learn on. If you run out and buy a poweredge server, you're still going to have to configure RAID sets...
    Ludicrous gibs!
  • Serendipity
    edited August 2011
    I am starting to think that the jumpers on the back of the drives are set wrong?
    You mentioned that for PATA raid, only 1 drive per cable can be used for RAID.
    I have one drive set as "Master" and another as "Slave" on the black cable, and the single Maxtor drive on the gray cable set as "Cable Select." I think this is making it look for another drive. How do I set the lone Maxtor drive to "Single"?
    Edit: If the lone drive is set to Master, the machine hangs at boot. Maybe no jumper at all = Single?
  • Serendipity
    edited August 2011
    Finally got it. Nowhere on the drive did it say that removing the jumper = Single Drive, but that's what it took to get this to work. Now I got into the RAID card's BIOS, and it has a bunch of options (labeled 1, 2, 3, 4, etc.) to create a RAID array and mirror the drives.
    I have to get my read on - the manual that came with the card is still in the box!
    Also have to install the driver CD that came with the motherboard - graphics is funky.
    txcoastal1 Posts: 13,500
    edited August 2011
    Please let us know how many and what size and model drives you have for each drive...plus do you intend to have an OS drive only...maybe we can help
    Cheers
  • Serendipity
    edited August 2011
    Thanks for all the help, the drives are the following:
    Single WD2500JS-75NCB3
    Single Samsung SP0842N
    (2) Maxtor 4D040H2
    edited August 2011
    You really only have 1 option since the drives are not the same size...your single WD as an OS and RAID 1 (mirror) with maxtors this would only give you 40gigs of storage.
    Raid 5 requires 3 or more drive but you give up storage capacity of one drive because it becomes a Parity
  • Serendipity
    edited August 2011
    That's fine, it's all Word documents anyways that need to be backed up...
    I don't need that much storage just reliability. If the need increases I can always throw in larger drives later.
  • Serendipity
    edited August 2011
    These drives were relatively cheap so I may be better off with new(er) drives.
    http://www.microcenter.com/single_product_results.phtml?product_id=0345153
    http://www.microcenter.com/single_product_results.phtml?product_id=0355468
    The 40gig was the cheapest PATA I could find and the 250gig was the most basic SATA drive.
  • nadams
    nadams Posts: 5,877
    edited August 2011
    If you need reliability, I'd dump the Maxtor drives.
    Ludicrous gibs!
  • Serendipity
    edited August 2011
    I'm trying to add another drive... this one uses the regular (ATA) power connector but all I have left are SATA power connectors.
    Can I cut off the power supply's SATA power connector and put on a regular power cable salvaged from a dumpster PC? This is the power cable I am trying to solder on after I cut the SATA connector off:
    There are two black wires - I take it both are interchangeable?
    See pic. Thanks!
  • Sherardp
    Sherardp Posts: 8,038
    edited August 2011
    Yes you should be able to wire it in yourself.
  • Serendipity
    edited August 2011
    Thank you sooooooo much... you are a life saver!
  • BeefJerky
    BeefJerky Posts: 1,320
    edited August 2011
    Or, you could just get a Y adapter and split off of another power connector.
    http://www.frys.com/product/4586747?site=sr:SEARCH:MAIN_RSLT_PG
  • Serendipity
    edited August 2011
    Yes, but I would think that by splitting off another (already used) power connector, the power supply would be loaded unevenly vs. cutting off an unused SATA power connector and changing the end to a regular ATA power connector. (This is what I am doing)
    Unless the power supply's internal SATA and ATA power rails are wired together... who knows...
  • BeefJerky
    edited August 2011
    Most power supplies have a single rail for each voltage. Some of the higher wattage ones will have more than one rail, but if so, it would be shown on the sticker where the PSU's current ratings are. Even so, loading them unevenly isn't a problem. As long as you don't go over the current rating of a particular rail, you are fine.
