Amp with No remote On / Off Trigger. What do you guys do?
jbooker82
jbooker82 Posts: 1,627
edited August 2011 in Electronics
Well I just bought my first amp. It is a Carver A-753x 250w x 3channels.
I believe it does not have a remote on / off trigger.
What do you guys do? Leave it on all the time, Shut it off with the switch every night, Use a smart power strip that shuts outlets off when the controlling device is shut off.
I have a smart power strip and can move things around so the amp could be plugged in to an auto on/off power outlet.
I didnt know if using one of those automatic power stips would be hard on the amp.
Thanks for the time.
AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II
Post edited by jbooker82 on
  • maod
    maod Posts: 12
    edited August 2011
    I use the surge protected power strip to turn on and off all my electronics.
    tonyb Posts: 33,069
    edited August 2011
    I just leave mine off, don't like plugging any amps into power conditioners or such. After all, if I'm too lazy to turn on a switch, I have bigger issues.
    I do however, turn things on in advance to listening to let everything warm up.
    EndersShadow Posts: 17,694
    edited August 2011
    Mine is on all the time, but Niles Audio makes a 4 channel powerstrip that has one outlet that can be setup to use a 12v trigger.
    So you could use that if it helped.
  • stuwee
    stuwee Posts: 1,508
    edited August 2011
    I kinda cheated, I leave the amp on all the time in my other systems, I can't with the main rig with Martin Logan's, they have a signal trigger that turns the juice to the panels on, attracts dust...Bad! So the Yammie gets shut off when not in use.
    I've heard, and could be wrong that you shouldn't use a power strip to switch an amp on and off because it might send a spike through, I guess that depends on the strip being used, but I'd use caution with that all the same.
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • jbooker82
    edited August 2011
    Well right now I have a power / surge protector that has 4 oulets that automaticaly power on and off when you turn what ever is pluged in to the controling out let on and off. It isnt a 12v trigger system.
    I have my Onkyo plugged in to the controling out let. So when I turn it on and off it causes 4 other oulets in the power stip to turn on and off. Right now I have my DSW PRO 550WI, Wii, and wirelss bridge (so my tx-nr808 is wireless) plugged in to the automatic on and off outlets. I plan on using one with this amp so it will turn on and off with my AVR.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited August 2011
    I use my finger or toe if i am too lazy to bend down, and press the button.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • jbooker82
    edited August 2011
    stuwee wrote: »
    I can see that happing too. That is what I was curious about. My power strip dosnt seem to do a hard shut down and start up. The sub plugged in to it doesnt thump when it turns on or off.
    I cant remember wich one it is but it is a Monster Cable brand. I Know I know, but I figured it would be better than a wal mart know name brand when I bought it.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
