AnyDVD, DVDFab,or what
burdette
I've been using DVD Decrypter and DVD Shrink for years. Generally they work great - actually Shrink is usually sufficient.
But I've noticed I'm having more and more movies that I can't copy. Most recently neither Shrink nor Decrypter would crack Battle for Los Angeles.
I've read about AnyDVD and DVDFab. Both (apparently?) break decryption and are relatively easy to use. (Although, I can't figure out the difference between DVD Fab and another product on the same site, Passkey for DVD - does DVD Fab break encryption?)
Looking for some advice/insight/recommendations on either of those or any other decrypter in the $40-$50 range.
Thanks.
Thanks.
Post edited by burdette on
I use DVD fab 8 of the 200 dvd's I have ripped only 1 didnt work but I think the dvd was bad.TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX -
Thanks. My boss also uses DVD Fab, but I like to get opinions here.
Hot Springs, huh? I'm in LR. Been here 3 years as of July. -
I'm a DVD Fab user myself. I used AnyDVD back when I used Handbrake to rip DVD directly to MP4 because it saved a step. But now I rip everything directly to ISO and DVD Fab does it in one step for me.
DVD Fab is an actual ripping program with a GUI, AnyDVD is just a service that runs in the background so you'd still need a ripping programs.
So in short, if you already have a ripper program that you really like, AnyDVD is the way to go. If you're looking for a good all in one solution, DVD Fab. -
Used both and both a good. I kind of like AnyDVD since it allows me to use DVD Decrypter still. However, as mentioned above DVD Fab has a lot more functionality.
I use AnyDVD and like it.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
.....review of best 10 and comparison.
Installation & Setup: The setup is straight-forward and requires you to reboot the machine after the install. We like how 1Click DVD Copy PRO has played it smart by Legally Integrated CSS decryption. During first time setup, you will install a free decryption utility. Once you set that up, copying any DVD is as easy as "1 Click".
http://dvd-burning-software.toptenreviews.com/ -
I like AnyDVD, but that is because it works for Blu-rays also...HT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
Outlaw 970 Preamp, Outlaw 7700 Amp, Velodyne SMS-1, Oppo BDP-83,
2 APC H-15s and a Panamax 5400 for good measure
Stereo: DIY Alix Music Server, DODD Audio Battery Tube Buffer, Modded DAC-60 and MF V-Link (for now), DIY Silver ICs, Battery Powered Class D SDS-254 Amp, and GR-Research N2X Speakers -
do you use just the converter or the whole software package? i'm not up on spending 79.99 for the whole thing but converter for $50 sounds more what i'm looking for..Main 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22 -
...I use to use the whole package. After you installed the program you were then required to download the decryption utility which was updated occasionally to keep up with the technology. Very simple....never had a problem.
Hi burdette...always good to see you...but I dont know much about your question.
RT1
