IB sub questions
Ron-P
I was contemplating the idea of going with an IB sub instead of the box that's in the room. My HT room is a dedicated room in the garage. I have one 15" Tempest and a 250w plate amp. Is this enough for a room that's roughly 16x9? I do not want to buy another sub just to test the idea if it will work or not. At least for testing purposes I'd have to install the sub in the back of the room, not the front. Would this create sound issues? Would doing this also create a lot more sound noise outside the theater room in the garage?
If...
Ron loves a film = don't even rent.
Post edited by Ron-P on
Google "cult of the infinitely baffled" & you'll find everything you ever wnated to know about IB.....TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Low volume yes. You also need to check the Q of that driver to make sure it'll work for IB- AND BE CAREFUL TURNING UP THE VOLUME. Messing around with IB is a great way to fry a driver.I was contemplating the idea of going with an IB sub instead of the box that's in the room. My HT room is a dedicated room in the garage. I have one 15" Tempest and a 250w plate amp. Is this enough for a room that's roughly 16x9?
Not really. Assuming you cross it around 40hz, you probably won't notice. 80hz, you will be able to tell it's in the back, but for movies that would be fine.I do not want to buy another sub just to test the idea if it will work or not. At least for testing purposes I'd have to install the sub in the back of the room, not the front. Would this create sound issues?
Yes. There's as much SPLs going out the front as the back.Would doing this also create a lot more sound noise outside the theater room in the garage?Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
No one using an IB will tell you putting it at the back of the room is a good idea.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
That setup will be far from optimal."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I know, it was just a thought. Something worth trying. I did, at one point, have my sub in the back of the room, in a box, behind the seating and it was not noticeable. It was x'd over so low you could not tell where the sub was.If...
