IB sub questions
Ron-P
Ron-P Posts: 8,520
edited August 2011 in DIY, Mods & Tweaks
I was contemplating the idea of going with an IB sub instead of the box that's in the room. My HT room is a dedicated room in the garage. I have one 15" Tempest and a 250w plate amp. Is this enough for a room that's roughly 16x9? I do not want to buy another sub just to test the idea if it will work or not. At least for testing purposes I'd have to install the sub in the back of the room, not the front. Would this create sound issues? Would doing this also create a lot more sound noise outside the theater room in the garage?
If...
Ron loves a film = don't even rent.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited August 2011
    Google "cult of the infinitely baffled" & you'll find everything you ever wnated to know about IB.....
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • unc2701
    unc2701 Posts: 3,587
    edited August 2011
    Ron-P wrote: »
    Low volume yes. You also need to check the Q of that driver to make sure it'll work for IB- AND BE CAREFUL TURNING UP THE VOLUME. Messing around with IB is a great way to fry a driver.
    Ron-P wrote: »
    Not really. Assuming you cross it around 40hz, you probably won't notice. 80hz, you will be able to tell it's in the back, but for movies that would be fine.
    Ron-P wrote: »
    Yes. There's as much SPLs going out the front as the back.
    Backburner:Krell KAV-300i
  • quadzilla
    quadzilla Posts: 1,543
    edited August 2011
    No one using an IB will tell you putting it at the back of the room is a good idea.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • Face
    Face Posts: 14,340
    edited August 2011
    That setup will be far from optimal.
  • Ron-P
    Ron-P Posts: 8,520
    edited August 2011
    I know, it was just a thought. Something worth trying. I did, at one point, have my sub in the back of the room, in a box, behind the seating and it was not noticeable. It was x'd over so low you could not tell where the sub was.
    If...
