Polk CS245 vs. CS1?
frdranger
frdranger Posts: 110
edited August 2011 in Speakers
Hey folks. I was just offered a Polk Audio CS245 center speaker for $75. I currently have a Polk Audio CS1 center speaker. I am having quite a hard time finding reviews, comparisons between the two. Is the CS245 worth it; is it better than the CS1? Thank you!
My Living Room 3.1 config:
Toshiba 40RV525U
Receiver: Onkyo TX-NR609
Center channel: Polk CS1
Front L/R: Paradigm Reference Studio 20
Subwoofer: Velodyne DPS-10
Rears: None
My Computer setup
Klipsch Pro Media 2.1 THX
Post edited by frdranger on
  • rooftop59
    rooftop59 Posts: 8,120
    edited August 2011
    In short, yes it is better. better cabinet, better drivers, crossover components, everything. it is basically the same as the cs245i, of which there are reviews to be found. It would make your mains better as well.
    Game Room 5.1.4:
    Bedroom 2.1
  • frdranger
    edited August 2011
    rooftop59 wrote: »
    thank you for your quick response!! I was thinking that the CS245 was actually inferior to my CS1 being it is older, etc. I can get the guy down to $50 on the CS245, so I guess I will go for it! Been looking for a better center channel for a while now without breaking the bank. Thanks!
    Your saying they would match my Paradigms better?
    Toshiba 40RV525U
    Rears: None
    My Computer setup
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited August 2011
    Rooftop's right, the 245 is superior to the CS1. Much fuller, less bright. I don't know how it match with your Paradigms though.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • frdranger
    edited August 2011
    Alright, great! Thank you guys for your responses. :) I thought they would be literally even - in terms of sound quality; if that the CS1 would have been a littler better. But thank you for your responses!
    Toshiba 40RV525U
    Rears: None
    My Computer setup
