Polk CS245 vs. CS1?
Hey folks. I was just offered a Polk Audio CS245 center speaker for $75. I currently have a Polk Audio CS1 center speaker. I am having quite a hard time finding reviews, comparisons between the two. Is the CS245 worth it; is it better than the CS1? Thank you!
My Living Room 3.1 config:
Toshiba 40RV525U
Receiver: Onkyo TX-NR609
Center channel: Polk CS1
Front L/R: Paradigm Reference Studio 20
Subwoofer: Velodyne DPS-10
Rears: None
My Computer setup
Klipsch Pro Media 2.1 THX
Toshiba 40RV525U
Rears: None
My Computer setup
Post edited by frdranger on
In short, yes it is better. better cabinet, better drivers, crossover components, everything. it is basically the same as the cs245i, of which there are reviews to be found. It would make your mains better as well.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
thank you for your quick response!! I was thinking that the CS245 was actually inferior to my CS1 being it is older, etc. I can get the guy down to $50 on the CS245, so I guess I will go for it! Been looking for a better center channel for a while now without breaking the bank. Thanks!
Your saying they would match my Paradigms better?My Living Room 3.1 config:
Toshiba 40RV525U
Rears: None
My Computer setup
Klipsch Pro Media 2.1 THX -
Rooftop's right, the 245 is superior to the CS1. Much fuller, less bright. I don't know how it match with your Paradigms though.Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
Alright, great! Thank you guys for your responses.
I thought they would be literally even - in terms of sound quality; if that the CS1 would have been a littler better. But thank you for your responses! My Living Room 3.1 config:
Toshiba 40RV525U
Rears: None
My Computer setup
