Mark Levinson No23 = Dead
swegyptian
swegyptian Posts: 316
edited September 2011 in Electronics
So I've got a pair of Mark Levinson No23 amps, and after not using them for six months, it turns out that one has died. I flipped the switch, it made a buzz, and then turned itself off. This was with nothing connected to it, so it's not a cable or speaker issue. So off to my tech it goes, hoping for a reasonable repair. I'm a bit sad at this point...
  • ESavinon
    ESavinon Posts: 3,067
    edited August 2011
    Good Luck. It cost a fortune to fix ML equipment.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • swegyptian
    edited August 2011
    Ya, I'm not excited about this one...
  • Sherardp
    Sherardp Posts: 8,038
    edited August 2011
    Wondering how much you looking at. Sounds like caps maybe shot.
  • swegyptian
    edited August 2011
    So now the amp stays on, but only one channel works. Perhaps something was on its was out, and causing a short. No more short, but only half working. I'll drag it in sometime this week.
  • TouchOfEvil
    TouchOfEvil Posts: 967
    reported post #6
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
