Can anyone identify these subs?
breal74
http://portland.craigslist.org/clk/ele/2540763154.html Very curious as to what they are and if they are worth $50.
Post edited by breal74 on
Not worth $50 to me. They're actually a frankenpolk SDA-CRS. It's a shame they've been butcher. The moron screwed up one tweeter (the main tweeter actually; the dimensional tweeter is still there) and installed car subwoofers in place of the passive radiator. To revitalize them, you'll probably need to replace all the drivers. Don't bother.polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter -
Thanks Bobsama.
For only $50, even if you had to replace the drivers I still think it's worth it. Hell, the seller even says "best offer". I say go for it.Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
For $50 OBO I would be all over that.--Gary--
HTguru1982 wrote: »For only $50, even if you had to replace the drivers I still think it's worth it. Hell, the seller even says "best offer". I say go for it.
In an unmolested CRS the bass driver is a passive radiator. If the seller installed a powered woofer that means he probably fubar'd the x-overs. So it's not a matter of buying a couple drivers. Plus, the passive radiators haven't been available from Polk for years which means he'd have to source used ones.
A whole lot of hassle for something that is fairly common in unmolested form. If they were super duper rare then rebuilding would be an option, but he'd basically have to build these from the ground up if the franken-woofer turned out to be powered.
Just my .02c
Think I'm going to pass guys. Thanks for the details H9!
IMO if the MW's work they are worth $50 easily. He "could" just have that sub in there using it as a passive radiator, not even hooked up. I'd check them out if I were close.--Gary--
Don't forget Murrphy 3 rd law--- "once a job is screwed up anything done to fix it makes it worse."Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
They're gone....:eek:Most people just listen to music and watch movies. I EXPERIENCE them.
Ones a cheesesteak and the other is Italian ColdcutI got static in my head
