Can anyone identify these subs?
breal74
breal74 Posts: 324
edited August 2011 in Vintage Speakers
http://portland.craigslist.org/clk/ele/2540763154.html Very curious as to what they are and if they are worth $50.
Post edited by breal74 on
  • Bobsama
    Bobsama Posts: 526
    edited August 2011
    Not worth $50 to me. They're actually a frankenpolk SDA-CRS. It's a shame they've been butcher. The moron screwed up one tweeter (the main tweeter actually; the dimensional tweeter is still there) and installed car subwoofers in place of the passive radiator. To revitalize them, you'll probably need to replace all the drivers. Don't bother.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • breal74
    breal74 Posts: 324
    edited August 2011
    Thanks Bobsama.
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited August 2011
    For only $50, even if you had to replace the drivers I still think it's worth it. Hell, the seller even says "best offer". I say go for it.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • halo71
    halo71 Posts: 4,638
    edited August 2011
    For $50 OBO I would be all over that.
    --Gary--
    heiney9 Posts: 25,506
    edited August 2011
    HTguru1982 wrote: »
    In an unmolested CRS the bass driver is a passive radiator. If the seller installed a powered woofer that means he probably fubar'd the x-overs. So it's not a matter of buying a couple drivers. Plus, the passive radiators haven't been available from Polk for years which means he'd have to source used ones.
    A whole lot of hassle for something that is fairly common in unmolested form. If they were super duper rare then rebuilding would be an option, but he'd basically have to build these from the ground up if the franken-woofer turned out to be powered.
    Just my .02c
  • breal74
    breal74 Posts: 324
    edited August 2011
    Think I'm going to pass guys. Thanks for the details H9!
  • halo71
    halo71 Posts: 4,638
    edited August 2011
    IMO if the MW's work they are worth $50 easily. He "could" just have that sub in there using it as a passive radiator, not even hooked up. I'd check them out if I were close.
    --Gary--
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited August 2011
    Don't forget Murrphy 3 rd law--- "once a job is screwed up anything done to fix it makes it worse."
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    Tony M Posts: 11,728
    edited August 2011
    They're gone....:eek:
  • rromeo923
    rromeo923 Posts: 1,513
    edited August 2011
    Ones a cheesesteak and the other is Italian Coldcut
    I got static in my head
