Intermittent distortion/popping Pioneer Elite VSX-35TX
hagmanm2
hagmanm2 Posts: 205
edited August 2011 in Electronics
I'll try and keep this short and sweet.
First the problem: the receiver will intermittently (with no perceivable consistency) produce a loud popping noise that may be brief, or may continue as loud static (very similar to the noise of a radio station with no signal: white noise).
Trouble shooting: the noise is produced through every speaker and on every input (regardless as to whether or not an IC is plugged into the input the receiver is set to). The noise will diminish or increase if I adjust the volume, but it's always louder than what a source would play at at the same volume. ICs have been swapped, speakers and speaker cables have been swapped, power outlets have been swapped, and sources have been swapped but the same noise occurs.
Sometimes the receiver stays on for a few hours without making a noise, sometimes it occurs within 30 minutes.
I'm at a loss, I've taken the dust cover off and didn't seen any signs of blown caps or shorts etc. ... though I wouldn't say it was an extremely thorough look since I didn't really know what I was looking for. If you guys have any other suggestions I'd greatly appreciate it. I'd love to be able to salvage this receiver.
Thanks guys!
Living Room: Receiver: Pioneer Elite SC-25 | Turntable: Technics SL-B200 | CD Player: Rotel RCD-955AX | Fronts: Polk RTiA3 | Center: Polk CSi A4 | Rears: Polk FXi3 | Sub: Velodyne DPS-10 | Cables: AudioQuest Type4 & TypeA
Office: Carver HR-742 | Speakers: RTi6 | Turntable: Numark 1600
Post edited by hagmanm2 on
    F1nut Posts: 51,763
    edited August 2011
    Seems like it's time for a trip to the repair shop.
  • mantis
    mantis Posts: 17,377
    edited August 2011
    I'm wondering if it's Digital or the soft muting circuit went bad. Agreed with F1nut , take it in for repair.
    Dan
  • hagmanm2
    hagmanm2 Posts: 205
    edited August 2011
    booo, aren't you guys supposed to come up with a quick and painless (and free) solution? with the resale value of this receiver, I'm not sure it's worth repairing. :\/
    I may need to deliberate.
    BTW, I just had a fantastic evening of music listening with my Adcom and some good friends. Sadly it will be gone tomorrow. Also, I like scotch.
  • falconcry72
    falconcry72 Posts: 3,580
    edited August 2011
    hagmanm2 wrote: »
    haha, good for you, man; that's what this hobby is all about: listening enjoyment! mmmm scotch...
