CS-10 Side Panel Removal
I'm trying to make space avialble next to two amps. I'm wondering if it's possible to remove the glossy black side panels on each side the CS-10. Has anyone done that and is it possible without distroying the speaker?
Post edited by Daniel22 on
Why would you want to do that?
Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
I have a shelf space under the TV that is 54 inches. I want to put two amps and the CS-10 on this self. The problem is that the width of the two amps and the CS-10 exceeds the 54" by a little more than 1/2". Removing the side panels would give me the needed space.
You might want to rethink your idea.Those amps should have some room to breathe.Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix
