Monitor 50 or 60 for HT?
jonnythan
jonnythan Posts: 3
edited August 2011 in Speakers
I had a set of R30s with a CSi25 center. I recently upgraded to a CS2 center and am surprised at how much better it is than the CSi25 was.
Now I want to upgrade my mains. Thinking about the M50s and the M60s. The M60s are $100 more for the pair. Is there that big a difference? What will I hear in the 60s that I won't in the 50s (or the R30s for that matter)?
This is 100% theater use, and I have an excellent subwoofer.
Post edited by jonnythan on
    EndersShadow Posts: 17,689
    edited August 2011
    jonnythan wrote: »
    You will get more mid with the 60's due to the increase in total woofer size, and will get more low end if you listen to direct or 2 channel music w/o your sub, but mostly they will give you more mid due to adding another woofer.
    They are worth the extra coin IMHO.
  • jonnythan
    jonnythan Posts: 3
    edited August 2011
    Thanks. I am leaning towards the M60. I live in an apartment where I can't really turn the volume up right now, but I figure that when i do move they'll fit into a larger space a little better.
    Any other comments? Anyone used both?
  • Geoff4rfc
    Geoff4rfc Posts: 2,805
    edited August 2011
    The 70's are awesome for HT, but it you're not going that way, definitely the 60's over the 50's.
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
