Monitor 50 or 60 for HT?
jonnythan
jonnythan Posts: 3
edited August 2011 in Speakers
I had a set of R30s with a CSi25 center. I recently upgraded to a CS2 center and am surprised at how much better it is than the CSi25 was.
Now I want to upgrade my mains. Thinking about the M50s and the M60s. The M60s are $100 more for the pair. Is there that big a difference? What will I hear in the 60s that I won't in the 50s (or the R30s for that matter)?
This is 100% theater use, and I have an excellent subwoofer.
Post edited by jonnythan on
    EndersShadow Posts: 17,704
    edited August 2011
    jonnythan wrote: »
    You will get more mid with the 60's due to the increase in total woofer size, and will get more low end if you listen to direct or 2 channel music w/o your sub, but mostly they will give you more mid due to adding another woofer.
    They are worth the extra coin IMHO.
  • jonnythan
    jonnythan Posts: 3
    edited August 2011
    Thanks. I am leaning towards the M60. I live in an apartment where I can't really turn the volume up right now, but I figure that when i do move they'll fit into a larger space a little better.
    Any other comments? Anyone used both?
  • Geoff4rfc
    Geoff4rfc Posts: 2,838
    edited August 2011
    The 70's are awesome for HT, but it you're not going that way, definitely the 60's over the 50's.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
