Wire set up
doug lang
doug lang Posts: 261
Aways confused with this. My receiver Integra supports arc and tv Sansung supports Arc. So one hdmi to tv from receiver to arc hook up. Blue ray hdmi and sat box hdmi to receiver. This is what manual says, do you agree this would be correct. Thanks
Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Post edited by doug lang on
    txcoastal1 Posts: 13,519
    edited August 2011
    http://www.hdmi.org/manufacturer/hdmi_1_4/arc.aspx
    The bottom half of link is a good explanation
  • doug lang
    edited August 2011
    worked very well and very easy to hook up. Thank you
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
