LS 90 Question
stubby
Hey all, just picked up a pair of pretty nice LS 90s and one of them is showing some strange behavior. The top two midwoofers will occasionally flutter with even a low signal sent to them. They don't bottom out and they don't do it all the time. Any suggestions as to what may be the problem?
I will also have to replace the tweeters as they have some off brand titanium jobbers in them now. Are there replacements available from Polk?
Thanks in advance - looking forward to getting these puppies back into shape!
stubby
stubby
SRS 3.1TL
Harman Kardon Citation 5.1
Anthem AVM2
Anthem AVM2
Post edited by stubby on
stubby
If Polk doesn't sell the tweets, I guarantee you someone here has a set."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I've got a driver or two and some tweets that I won't probably use in the near future - if interested, PM me and we can work something out.
switch a good driver with the one that is fluttering. if the problem follows the driver, it is the driver.....if it doesnt. its in the crossover (my guess, as I assume it has aftermarket tweets for a reason.
I had a pair of those, badass speakers....worth a little effort to get them 100%Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
If it's what I'm thinking of what your describing, they're just old and the driver vc and spider are worn out. They will eventually fail so I'd look for replacements now.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
First thought would an air leak but if the top drivers share the same volume as the other two they all would exhibit the behaviour.You might try swapping sides with the speaker cables to be sure the problem isnt something source/amp related.. The top two midwoofers will occasionally flutter with even a low signal sent to them. They don't bottom out and they don't do it all the time. Any suggestions as to what may be the problem? -
If you take the bad speakers out, look at that accorian looking disc behind the cone and see if it has come loose from the cone or metal basket. If it has, you can reglue it.Hey all, just picked up a pair of pretty nice LS 90s and one of them is showing some strange behavior. The top two midwoofers will occasionally flutter with even a low signal sent to them. They don't bottom out and they don't do it all the time. Any suggestions as to what may be the problem?
stubby
I would think if a spider was detached there would be obvious audible side effects with it flopping around.
That would be my guess too, detached spider. I've seen it before.
StanStan
Main 2ch:
HT:
Other stuff:
Took the drivers out and they look OK. Re-installed them and could not duplicate the flutter, but there is a rasping sound coming from them, especially noticed at low sound levels. If you push on the driver slightly, the rasping sound stops for a while. I think the voice coil is on it's last leg.
Many thanks for all the help, and DaveMuell you have a PM about some spare parts!
stubbySRS 3.1TL
Anthem AVM2 -
As an aside, has anyone considered upgrading the internal wiring on their LS series speaker? I swear it looks like 18 guage out of a Monitor 4. I know size isn't everything but..........
stubbySRS 3.1TL
Anthem AVM2 -
Well since you are actually hearing distortion even at low levels it may be that the spider has separated from the base of the cone.By pushing in the cone you might be momentarily realigning them?Took the drivers out and they look OK. Re-installed them and could not duplicate the flutter, but there is a rasping sound coming from them, especially noticed at low sound levels. If you push on the driver slightly, the rasping sound stops for a while. -
I had a woofer with that problem (the audible problem) and I eventually had to buy a new driver.
Dan -
Sometimes you can get a temporary fix to the problem by gently pushing in the driver from the outer edge. It may last for a couple of minutes or a couple of hours,lol, eventually you'll get tired of doing that and just buy some used or new replacement Polk drivers. They are a breeze to replace. Dave's a great guy and will fix you up:)
Polkie2009 wrote: »Sometimes you can get a temporary fix to the problem by gently pushing in the driver from the outer edge. It may last for a couple of minutes or a couple of hours,lol, eventually you'll get tired of doing that and just buy some used or new replacement Polk drivers. They are a breeze to replace. Dave's a great guy and will fix you up:)
I think I jsut figured out why I can't find my surplus drivers - I sold them to you with the 90's, didn't I? -
Lol, Dave I thought maybe you had found a couple more somewhere:) Stubby, I need to hang onto these in case I need a backup in the future. Hopefully someone else can chime in with some extras for you. Or you can get new ones through Polk Audio ,tell them you're a CP member and you'll get a discount:)
Polkie2009 wrote: »Lol, Dave I thought maybe you had found a couple more somewhere:) Stubby, I need to hang onto these in case I need a backup in the future. Hopefully someone else can chime in with some extras for you. Or you can get new ones through Polk Audio ,tell them you're a CP member and you'll get a discount:)
No worries, I understand the need for spares. I have seen the tweeters on ebay and Polk is just a call away. Thanks to all for their input.
stubbySRS 3.1TL
Anthem AVM2
