Bridging the Gap: SDA to Magnepan
falconcry72
falconcry72 Posts: 3,580
edited August 2011 in 2 Channel Audio
I have two pairs of speakers in my two-channel system that I alternate between regularly. Here's what they are and why I like them:
Polk Audio SDA-1C's: warmth, liquid midrange, enveloping soundstage, powerful but natural bass.
Magnepan 1.6QR's: detail, speed, delicacy, imaging, realism, transparency.
I leave the SDA's setup in their perfect positions at all times and move the maggies into or out of position when I am or am not using them. This is pretty easy because the maggies are so light plus their stands slide nicely on the linoleum floor, and I have their positions marked on the floor with duct tape. See pics. The longest I go without switching is a week or two; other times I switch 5 times in one day.
I absolutely prefer the SDA's on some recordings, and I absolutely prefer the Maggies on other recordings.
I want a loudspeaker that can be the best of both worlds and do what I like about both the maggies and SDA's, but better.
*** I am not looking for a compromise or a middle ground. I am looking for a loudspeaker that does what the maggies and SDA's do at least AS WELL, if not BETTER. Otherwise, I'll just keeping switching between these two; I don't mind.:wink:***
I'm only looking to spend between 1k-2k on the used market, so I don't know if what I'm looking for exists in that range. I could get a pair of 1.7's, but I'm too early in my audio career to get pinned into a brand; I want to try new designs.
I'm thinking Theil. 3.6 or 2.3.:cool:
Other suggestions?:confused:
Thanks for the help, dudes!:biggrin:
Post edited by falconcry72 on
    heiney9 Posts: 25,396
    edited August 2011
    Good luck, because I doubt one exists that isn't some level of compromise. I'll wait for PFB to comment about Martin Logan's being it, but they aren't, not really close. I have the same dilema, as I have a couple friends that have modded Maggies. (Ricardo, DKG999, AL212) and I love them on some material and not so much on others compared to my 1C's.
    I still contend for myself and my listening habits SDA's are a great compromise and great all around performer, they don't one or two things really well, but they do a lot of things well enough to strike a nice balance that is easy to live with with all types of gear, rooms and recordings. Mine are modded and it does take them to the next level.
  • sda2mike
    sda2mike Posts: 3,131
    edited August 2011
    TL your 2Bs, then report back;)
  • Ricardo
    Ricardo Posts: 10,636
    edited August 2011
    -Get rid of the MDF frame on those maggies and make a wood frame.
    -Get some room treatments
    You won't want to listen to the 1C's anymore (Hi Brock..) :smile:
    SOPA
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2011
    sda2mike wrote: »
    You totally stole my thunder on this one.
  • falconcry72
    edited August 2011
    Ricardo wrote: »
    -...-Get some room treatments
    Room treatments are definitely coming. It is a VERY lively room. The ceilings are only about 7.5 feet, and I think they are the worst contributor for the maggies. I put down a couple rugs that helped, but the walls and ceiling need help big time.
    EndersShadow Posts: 17,687
    edited August 2011
    Maybe go 2.1 and add a sub???
    Toolfan66 Posts: 17,982
    edited August 2011
    You have the best of both worlds why mess with it??
    Mod your 1C's!!!
  • falconcry72
    edited August 2011
    heiney9 wrote: »
    ... Mine are modded and it does take them to the next level.
    hmm. It might be worth it to hot rod'em fully before moving on...
    I've got 194's, but the crossovers are stock.
  • falconcry72
    edited August 2011
    I run a Mirage BPS-150i with the Maggies. It does great. Very quick and accurate, as it uses 2 opposite firing 8's, and it's flat to about 22hz.
    Maybe I could get more bang for my buck if I went with monitors and kept the sub?
  • falconcry72
    edited August 2011
    sda2mike wrote: »
    hmm. TL'd 2B's vs modded 1C's. Tough call...
    nooshinjohn Posts: 25,877
    edited August 2011
    I wonder if the Maggie 3.6 QR would get the job done for you. They dig quite a bit deeper and have a ribbon tweet in them that is supposed to be superb.
  • falconcry72
    edited August 2011
    I've thought about that.
    The true ribbon in the the 3.6's is supposed to be where it's at, and they difinitely dig deeper than the 1.6's. hmm.
    It's actually a good time to buy them now that the 3.7's are out, but 3k is still a lot of money... eff it, maybe I'll just save up and delay the purchase; I'd probably be happier in the long run.
  • cstmar01
    cstmar01 Posts: 4,424
    edited August 2011
    I really enjoyed the Thiels I have but didn't have the bass as others. I liked them and they are very coherent compared to other things. I would think the 2.3s would be even better but haven't had a chance to hear them (would like to at some point).
  • Joe08867
    edited August 2011
    I would take SDA2BTL's all day over 1C's. But that is just my opinion.
    How big is the room?
    Can you set the Maggies on a longer wall? They like room to breath.
  • stuwee
    stuwee Posts: 1,508
    edited August 2011
    heiney9 wrote: »
    Martin Logan's are all that and a nickel bag of chips :tongue:
    If you go with the big Theils you better budget for a bigger amp dude.
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • falconcry72
    edited August 2011
    stuwee wrote: »
    ...If you go with the big Theils you better budget for a bigger amp dude.
    Really?
    My 2200ii is rated at 250W into 8 ohms, 385W into 4 ohms, per channel, and it's fairly high current at 50 amperes continuous, 90 peak.
    What kind of power would you recommend?
  • falconcry72
    edited August 2011
    stuwee wrote: »
    Martin Logan's are all that and a nickel bag of chips .
    Are there specific used models that show up regularly in the 1k-2k range that you would recommend?
    Aerius i?
    reQuest?
  • falconcry72
    edited August 2011
    Joe08867 wrote: »
    The room is essentially 40 ft long, because it opens to other sections, but only 13 ft wide. 13 ft is a little shallow to set them up the other way.
    Right now they're 3 ft from the side walls and 5 ft from the front wall. Bringing them that far off the front wall made a HUGE difference from when they were only 2-3 ft off.
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2011
    After Magnepan and other equally superb loudspeakers....SDA just isn't what it used to be. They will always be special to me which is why I'm holding onto my CRS+ and SRT. The perfect extremes of the entire brand....in two distinct models.
    There is one thing that Polk SDA's will always edge out almost every other speaker on the market, new or used. The fact you can pick any model....ANY model and have an excellent if not outstanding demo and experience. Other manufacturers should be so lucky.
    SCompRacer Posts: 9,079
    edited August 2011
    Ricardo wrote: »
    This guy is pretty smart, so I'd listen to him. I'm smarter though cause I had acoustic treatments before him.:biggrin: Make room treatments a priority.
    My second choice for speakers would be maggies with a sub. I already own my first choice and had SDA's.
  • Pycroft
    Pycroft Posts: 1,961
    edited August 2011
    Speaker listening is so subjective, but I will give my opinion. I have had SDA 1C's, and loved them. I think a good compromise may be Carver Amazings. I have heard them in an awesome system. They are also ribbon speakers, but with the bass that the Mangepan's are most likely missing. They may be the best of both worlds. They are huge, but it's an easy sacrifice. I would also throw into the ring, my speakers - the Sony SS-M9's. They are, by far, the most natural sounding, smooth, easy to listen to, balanced speakers I've heard. I don't have as much experience as many on here, but anyone who's heard my speakers has been wowed. If you find them on the used market, they go anywhere from 750 - 1500 dollars. I see them sometimes for upwards of 2500, but they can be had for less - but they are a rare find. If you do find them, make sure the tweeter, woofers, everything is intact, because it's very difficult to find replacement parts for the speakers. Any questions - don't hesitate to ask. I did write up a review of the speakers a while back, and a few others on here have them and I'm sure would be glad to talk about them.
    James
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
    tonyb Posts: 33,065
    edited August 2011
    There in lies the dilema for alot of people. You like x speaker but only on certain recordings, you get another set of speaks only to find out you only like it for a different set of music. I was in your shoes plenty of times. I wanted a speaker that could play any type of music and do it well enough to put a smile on my face no matter what I threw in the cdp. I found that speaker in the Legacy Focus 20/20, though someday I may hit up the newer HD model. Now, everyones mileage will vary on opinions of loudspeakers, there's just too many good speakers out there to get an ear on these days so don't limit yourself to SDA's or Maggies. You have to kiss alot of frogs to find your prince,so to speak. Other speakers you may want to give a whirl are the CS 2.3's, Vandy 5's, Salk HT3's, just to name a few that have stuck out in my memory. Montana also has my SQ nuts by the short hairs. Used, alot of these speakers can be had fairly reasonable but I feel any of them will take you to the next level, and thats not to say theirs another dozen or so speakers that would take you up a few notches too. Good luck on your journey.
  • markmarc
    markmarc Posts: 2,309
    edited August 2011
    My room is pretty similar at 14 x19. Spend $600 and get the Skiing Ninja crossovers for the Maggies, the difference is amazing. I always like the Maggie sound before, but the resolution improvement, etc. is worth every penny plus some. Of course, you could do the same for the SDA's, and experience the improvement as well.
    But definitely invest in some room treatments.
    Former Staff Member TONEAudio
    2 Ch. System
  • fbm211
    fbm211 Posts: 1,488
    edited August 2011
    What about the Vandersteen model 2 signature.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • inspiredsports
    inspiredsports Posts: 5,502
    edited August 2011
    The only thing I have to toss in is that in that size room, TL'd 2B's would shine.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • falconcry72
    edited August 2011
    Thanks to everyone for the suggestions. This can be a consuming hobby, and part of what I need to do is sit back and enjoy some tunes.:smile:
    I've narrowed it to two options:
    1) Room Treatments
    2) Magnepan 3.6's
    It makes the most sense to me to do the treatments first. Room acoustics is without a doubt the weakest link in my system, so I should bring that up to par with the rest of my system. Once the room is treated, I will be able to more accurately evaluate my current speakers and associated gear as well as any future gear.
    Now to go dig up some threads on budget, but quality, pre-made panels. I don't have time to make my own, and I'm going to need 7 panels and 2 bass traps without breaking the bank.
    Thanks again fellas!:biggrin:
    edited August 2011
    I'm a big fan of GIK. Some folks like RealTraps. A couple of my friends went with ATS. Here is a thread by Blake. He treated his room after a visit here. I pulled treatments out of the room while he was listening so he could hear the difference they made.
    http://www.polkaudio.com/forums/showthread.php?t=86154&highlight=room+treatment
    http://www.gikacoustics.com/
    http://www.atsacoustics.com/
    http://www.realtraps.com/
    GIK gave me their recommendations based on pictures and dimensions of my room. They also offer a broad array of Guilford of Maine fabrics that allow the treatments to match any decor. Dear wife picked the fabric out cause I am partially color blind. I experimented with different acoustic panel placement for my dipole speakers and did some burst frequency tests to confirm results. (In my experience, long duration frequency sweeps tend to load up the room and skew the readings).
    I wouldn't rush to replace your 1.6's yet. I have a South wall setup similar to yours that has both speakers boxed in symmetrical to corners. Behind my listening position is open to the main level with the nearest wall 25 feet away. My South wall setup requires more acoustic treatment for bass loading than my West wall setup which has the right speaker open to the main level.
    EDIT: Wanted to add a link to Ricardo's room. IIRC the width is similar to your room.
    http://www.polkaudio.com/forums/showcase/view.php?userid=64116
    F1nut Posts: 51,674
    edited August 2011
    Not at all, 2BTL's hands down.
  • stuwee
    stuwee Posts: 1,508
    edited August 2011
    Really?
    I remember one of the Stereophile guys testing a monster McIntosh pair of mono's rated at 1000w, and they said they got the clip lights lit with the big Theils. Or maybe it was a Boulder amp, anyway they like the juice.
  • stuwee
    stuwee Posts: 1,508
    edited August 2011
    Aerius i?
    reQuest?
    SL3's can be had for $1,000 or less, great speaker, the key to ML's is where they came from...did the owners vacuum them once a month? Did they smoke around them? Yes, that includes doobies :rolleyes:. Woofers can blow their surrounds with very high power, you really can't damage a panel with the juice. You need to hear ML's properly set up in a good room before you buy, they aren't for everyone. I'd don't know where you live, but in the bigger cities, the older models show up on CL. Sorry to jump on the ML soapbox, but you asked.
