For Trey & Ben - JBL L166 Crossover Upgrade?
PrazVT
PrazVT Posts: 1,607
edited July 2011 in DIY, Mods & Tweaks
My dad has been impressed w/ the XO mods on my LSi9s - and for someone who lectures me on spending money on audio stuff, he's been impressed w/ m 2ch and HT setups.
I was wondering how feasible it would be to do it - I've never cracked open those big boys so not sure how clean the xo setup is. Thoughts?
I think below is the circuit diagram and perhaps some stock crossovers for the L166s, as well as the speakers themselves. His are in great condition - I figure if he refuses to part with them, perhaps they can be upgraded ;)
Just an idea...
Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups.
Post edited by PrazVT on
    VR3 Posts: 29,534
    edited July 2011
    We can make it happen! :)
  • PrazVT
    PrazVT Posts: 1,607
    edited July 2011
    I had a feeling you'd be up for this - thanks! I'll take a closer look at the speakers this weekend - perhaps crack them open and take some photos. Most probably it'll be a month or two before he can do this, but I thought I'd quietly start the pre-work.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    VR3 Posts: 29,534
    edited July 2011
    Im down for anything with coils caps and resistors buddy!!
    OH YEAH! Crossovers pump me up!
  • zingo
    zingo Posts: 11,258
    edited July 2011
    Looks easy enough!
  • Pherd
    Pherd Posts: 1
    Hi guys! I just came across this quite old post with the same thing in mind - rebuilding the L166's crossover and then swapping it. Are you still around to share some insights about this project with me?
    F1nut Posts: 51,944
    The schematic is listed above showing the value of the 2 caps and 2 resistors. I also noted the sensitivity is rated at 76, 1 watt@ 3 meters. That's horrible!!!
    mhardy6647 Posts: 35,200
    edited April 2020
    Something does not seem right about that -- maybe that is the old EIA sensitivity spec, which was something like dB SPL at 30 feet (roughly ten meters, though) at 1 mW input power. https://www.diyaudio.com/forums/multi-way/119152-old-speaker-efficiency-rating-40s-db-print.html
    EDIT: hmm...
    http://www.lansingheritage.org/html/jbl/specs/home-speakers/1976-l66.htm
    Yeah, this says 40 to 46 dB EIA (= 89.2 to 95.2 dB SPL @ 1 meter / 1 watt), depending on driver/frequency range, which sounds mo' better.
  • PrazVT
    PrazVT Posts: 1,607
    Wow I barely even remember starting this thread lol. I didn't end up messing with the speakers as they were okay (still mains in my dad's ht).
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
