best audio connection from dvd
soundfreak1
soundfreak1 Posts: 3,414
Best audio sound from dvd, optical out , coaxial, or use the 5 ch.audio outs. Just courious if there is any audible diff. Equip. Used; demon 1940 ci into a b& k ref. 30 ( if this matters) driven by 5 ch. SS high current PA 2200 HK amp. Thanks in advance.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited July 2011
    Optical and digital coax should sound the same. Analog may sound different. Only your ears can tell which you'll like better.
    edited July 2011
    Digital connections are the best unless you plan on using a SACD player. If you use the analog connections,you will drop all the processing the B&K offers because it only does it in the digital domain.
  • soundfreak1
    edited July 2011
    Thanks, this sys. Is a dedacated HT no music i have 2 ch. Analog for that. Thought the optical would be beat thqnks for the comformation.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • djperez81
    djperez81 Posts: 388
    edited July 2011
    You decided not to sell the b&k?
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    edited August 2011
    I switched from Digital coax to Optical and could tell a difference immediately. But really, it's like mdaudioguy said, "only your ears can tell which you like better".
    Home theater:
    43” Westinghouse Displayer
    Marantz UD-7007 Player
    Emotiva MC-700 Processor
    Adcom GFA-5006 Amplifier
    Parasound Zamp Amplifier
    Ethereal ESO-1 Power Conditioner
    Klipsch RC-10 Center
    Klipsch R34c Fronts
    Klipsch RB-41 Surrounds
    Polk audio PSW-505
    Stereo:
    Polk audio RTA-12c’s fully upgraded crossovers
    DIY 12tc braided speaker cables
    Denon DVD-5910ci Spinner
    Parasound P6 Preamplifer
    Parasound HCA -1500a Amplifier
  • headrott
    headrott Posts: 5,496
    edited August 2011
    Which did your ears prefer Mr. Sharpe? Coax or Optical?
    Greg
  • Mr. Sharpe
    edited August 2011
    Optical. but to be totally honest that going from a crap cable from WalMart to Monster... soooo obviously anything is better than a Walmart brand lol
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • headrott
    edited August 2011
    Yes, to get an "equal" audio output signal, you should be using equivalent wire. That said, even the quality of the optical and coax jacks can have an effect.
    Greg
    edited August 2011
    I don't get why he uses both the denon and the ref 30. The b&k is light years better than the denon and he has a 5 channel amp. Digital connection from dvd into the Ref 30 , connect the amp and your off to the races.
  • kcoc321
    kcoc321 Posts: 1,788
    edited August 2011
    The Denon 1940 is his DVD player
    edited August 2011
    Ah..doh...gotcha. Slow tonight.:tongue::smile:
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited August 2011
    post 14 reported for clicky link in sig.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • Mr. Sharpe
    edited August 2011
    they're getting good at deleting spam messages before I even see them... that's good. I hate spam. it's annoying.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
